Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
PSP Slim & Light: Hold Button light not working wafc PSP 3 25-09-2007 6:09 PM
The ring of death or should that be just a light - ps3 with a red light ! pixelpixel PS3 15 21-11-2006 3:40 AM
Back Light settings on Back Light lifespan dlove LCD Televisions 0 15-08-2005 1:34 PM
Pw6 ist timer Garrymol Plasma Televisions 3 20-02-2005 6:41 PM
Looking for a timer to add to a ceiling light AVmaster Home Automation, Lighting, Security, Heating and Cooling 1 17-01-2005 11:13 PM
Old 13-12-2007, 8:39 AM   #1 (permalink)
Thanks: Gave 1, Got 3
Timer light switching
I planning to go away on holiday soon and I'd like to program our hall / bedroom lights to go on/off at various times.
What's easiest method for doing this ??? Is this a good application for Rako ? What modules would I need and how easy is Rako to fit ?? or should I stick with the tried and tested argos timer and lamp approached ???
Degs
DegsC is offline   Reply With Quote
Old 15-12-2007, 10:15 PM   #2 (permalink)
Re: Timer light switching
Sombody must have any idea....... Off to B&Q tommorrow
DegsC
Old 15-12-2007, 11:06 PM   #3 (permalink)
Thanks: Gave 158, Got 80
We just use cheap units on all of the lights we want to turn on-and-off. Simple little plastic unit with a timer and a switch on, under £10 at Argos or, I imagine, B&Q. You really needn't spend a great deal on this, the cheap ones seem to work fine if you program them correctly.
Astraeus
PSN: astraeus01 (FIFA 09, MLB 08, Tiger Woods 09, Rock Band, NHL 09, Fight Night R3)
My Flickr Page (Nikon D40, Nikkor 18-55mm f3.5-5, Nikkor 55-200mm VR f4-5.6, Lowepro Fastpack 200)
Astraeus is offline   Reply With Quote
Old 16-12-2007, 12:28 PM   #4 (permalink)
If you want to go slightly more upmarket, B&Q sell the Home Easy range of remote controlled mains adapters. There is a remote timer, which can set 12 on/off cycles for up to 12 different remote sockets, which can be dimmable or not. You can also get a keyfob size remote for about a fiver to switch on/off but not dim any socket it is paired with. Sockets can be paired with up to 6 remotes.
Well worth a look as they are not expensive and may have uses beyond the holiday.
stevex is offline   Reply With Quote
light, switching, timer
