Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Old 12-03-2007, 9:25 PM   #1 (permalink)
kdog's Avatar
Thanks: Gave 103, Got 65
Help: Zone Lighting
Hi Guys
Need some help with lights.
I don't say this very often but please treat me like a novice
I'm thinking of having 3 zones in my new kitchen/dining room. 20 or so low voltage spots with 1 control panel that has 5 buttons 1 for each zone and 2 for dimming up and down.
Does such a device exist and if so can someone please point me in the right direction?
Also is there anything I should look out for? How technical is this job, I'm thinking of doing this myself
kdog is offline   Reply With Quote
Old 12-03-2007, 11:02 PM   #2 (permalink)
vex
Assured Advertiser
Thanks: Gave 9, Got 181
Re: Help: Zone Lighting
Rako or GET SmartLight will do this for you.
Rako will re-call preset scenes across all three circuits and then dim them up or down.
GET can be set to recall either scenes or individual circuits (not interchangeable) and then dim them up or down.
HTH
Chris
vex is offline   Reply With Quote
Old 17-03-2007, 10:07 AM   #3 (permalink)
kdog's Avatar
I know this is really lazy, but does anyone have links for the rako product I should be looking at?
Old 17-03-2007, 10:12 AM   #4 (permalink)
Thanks: Gave 0, Got 13
some links:
www.rakocontrols.com
www.ilight.co.uk
www.dynalite.co.uk
www.zendimming.com
www.lutron.com
www.modelighting.com
All of these systems can do what you need. Just depends on how much you want to spend, and features you want.
Bruce_ is offline   Reply With Quote
kdog (18-03-2007)
Old 17-03-2007, 10:17 AM   #5 (permalink)
Just Google for rako, and you will see how many are now selling it online. Worth checking out which is cheapest.
kdog (18-03-2007)
lighting, zone
