Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 02-03-2007, 11:45 AM   #1 (permalink)
Wireless Routers and Wireless TV senders
hi
ive got a Netgear DG834GT wireless router ive heard that wireless tv senders can interfere with them is this true?
Ideally i would like a wireless PC to TV sender to allow me to send streaming football into the front room.
Can anyone recommend a sender that will allow me to do this?
my pc has both VGA and DVI outputs and the tv id like to link to is a Samsung LE32R74BDX
cheers
mike
mattressback is offline   Reply With Quote
Old 18-03-2007, 11:55 AM   #2 (permalink)
Thanks: Gave 1, Got 0
Re: Wireless Routers and Wireless TV senders
Could you be a be more clear on what you are wanting to achieve, are you intending to stream to your TV from your PC?
Is that what you are aiming to do?
They don't interfere but quality is very poor and they can be a bit hit and miss.
Sling box stream media from AV equipment onto the internet which you than can access via any pc if thats any help?
Mr P
IainP is offline   Reply With Quote
Old 18-03-2007, 12:38 PM   #3 (permalink)
hi, i can stream live football onto my pc (located in the bedroom) via the net but id like to send it from my pc to the 32inch tv in the front room
Old 18-03-2007, 9:11 PM   #4 (permalink)
Ah
Now it all becomes clear. Then yes i would go down the route of an AV sender, not having one myself i cant recommend a brand, but what i will say as i have dealt with them, what you pay for is what you get.
And remember most of these will only have a scart input. Sorry if i'm telling you how to suck eggs here. So some conversion may be required...
I would recommend going to argos because if the one you buy is rubbish, you can return in and get a refund saying it is poor, same with all major high street shops as they have a 14 day technology guarantee, where if its rubbish you can return it.
With regards to WI-FI interference, they do work on the 2.4GHZ range, and have a range of approx 30m but i'm unsure of the channels, i doubt that they will be the same as WIFI, but you can always change your channel on your router if there is a problem.
I hope this helps...
Mr P
Old 18-03-2007, 11:31 PM   #5 (permalink)
cheers, ill maybe give it a try somewhere down the line, ill let you know how i get on!
routers, senders, wireless
