Re: Installing spotlights
Originally Posted by owain_thomas
The reason is so that your loft insulation doesn't catch fire! halogens get pretty hot and need a decent amount of air around them to make sure they don't overheat and set things alight.
HTH
Whoa,  loft insulation should only be mineral wool or glass fibre which is totally non flammable. You shouldnt be using anything which may be combustible. The reason for removing the insulation from around the fitting is to ensure an airflow around the fitting so it nor the transformer if there is one doesnt overheat.
If in any doubt get a qualified electrician to do it for you.
You should be aware that Part P of the building regulations now requires anything apart from the simplest electrical works is notifiable to the LA or must be done by a qualified electrician.
TagMclaren DVD32FLR TAg AV32Rbp+psm Tag 100x5 power amp, Wilson Benesch Arcs, Tag Calliope centre. Velodyne CH10T sub, Loewe Connect 42+DR TV
