I know i have posted before with a similar thread but now things have changed and would like to start a fresh.
Firstly i need the following spec..
- DVR with the ability to record continously with 2 cameras
- Record sound from at least one camera.
- Have either cd or dvd backup facility
- If possible have the playback to be as smooth as normal movie (Not jerky)
- Need to ability to have both cameras on seperate channels for viewing live at the same time without having to flick between them.
I do have some questions that i would like answers too please..
How many fps equal smooth playback?
Can i add my own hard drive and if so does it have to be a certain type?
Do i have to format it or add software for it to work on the dvr?
What format would the backup be and can it be played on a dvd player?
__________________________________________________ _______________
Secondly i need 2 cameras
- 2 cameras at least 1 with sound or a good solution to seperate audio.(Both for external use).
- Ability so see in the dark at 20 metres.Prefer day/night (colour/mono) cameras
- clear picture day and night (Be able to see faces clear).
- If possible clear leds that don't show in the dark.(Not sure if these are available).
- Small and discreet as possible
- Also don't want to be paying more than £150 per cam
What sort of angle does night vision cover (is it mainly focused in the middle like a torch beam).
Do i need a wide angle lense?
What is the difference in lense sizes?
How do i determine which one i need?
Can a dome cameras be wall mounted and point downwards?
Do not want to go the pc route or wireless.
