Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Old 22-02-2007, 7:18 PM   #1 (permalink)
jagdeepp's Avatar
Thanks: Gave 174, Got 100
Strange goings on .. light switches off then on
Hmmm.. should i be calling ghostbusters?
My office has a number of power points. It has one light in the ceiling which recently blew... nothing untoward about that. I checked the bulb and noted it was a mere 25w bulb on 240v. That explained why the study was so dark.. I therefore put in a stronger bulb which i think is 60w. The light stays on then randomly goes off for around 3 seconds. It comes back on and randomly a couple of hours later will switch off for 5 mins and come back on itself.
My concern is that i wish to put some gu10s into the ceiling in due course. I'm concerned as to why its struggling to handle 25 watts. I bought this place last summer. I note that there are 5 power points in the office and there is a fused spur from where i can switch off the power. The lights run off a seperate circuit though?
Any and all help appreciated.. kindest regards and thanks in anticipation.
My Set up: Sony Panny PT-AX100 HD Projector, 2.2 metre HCSV electric screen, Arcam AVR350 amp, HTPC's with 1 TB, Monitor Audio RS6 5.0, BK Monolith, Nintendo Wii, Snazio 1310, Xbox 360,
My Home Cinema Lounge & Home makeover
jagdeepp is offline   Reply With Quote
Old 23-02-2007, 4:15 PM   #2 (permalink)
Thanks: Gave 1, Got 21
Re: Strange goings on .. light switches off then on
First please dont be offended but reading your post it is pretty obvious that you have a very very limited knowledge of house wiring and I would not want to offer you any advice other than get an electrician.
Regards
Steve
Ps I am an electrician but not looking for work.
Steve1951 is offline   Reply With Quote
Old 23-02-2007, 5:03 PM   #3 (permalink)
jagdeepp's Avatar
I hear what u say and i sound like a noob. You'll be surprised but i've installed 2 banks of gu10s in my lounge + added to fused spurs for power for my screen, plasma and projector so on a scale of 1-10 i'd say i'm just above 5. If you're an electrician there should be a straightforward response to this? Prefer an answer as opposed to cheek. When i use a lesser wattage bulb no probs. Wanted some general advice. Anyone else?
Old 23-02-2007, 8:47 PM   #4 (permalink)
Hi Again
As I said before I DO NOT want to offend anyone.
It is extremely easy to wire things up and get them to work.
There are 6 things you should consider
1)Safety
2)Regulations
3)Part P (Although you probably dont know what that is.)
4)Safety
5)Safety and
6)Safety
The times I have heard "well its worked ok up until now "whilst I am pulling out the burnt out wiring.
I will give you a straight forward response,its likely your wiring is shot and you have no idea what you are doing.
My advice was given with the best of intentions
If I were you i would cut out the middle man and call the fire brigade right now............hows that for cheek!
ELECTRICITY CAN AND WILL KILL
Old 24-02-2007, 11:34 AM   #5 (permalink)
Thanks: Gave 0, Got 13
Is there just the one light on that circuit? Does anything else turn on/off at the same time?
Is it controlled by a dimmer?
You might want to try switching off circuits at your switchboard, and see if the sockets are on the same circuit as the light (nasty wiring). Try to isolate what else goes off when you switch off the circuit that controls the light.
Id does sound like dodgy wiring though.
Bruce_ is offline   Reply With Quote
Old 24-02-2007, 1:00 PM   #6 (permalink)
jagdeepp's Avatar
I've got an uncle whose an electrician and will ask for advice. I've noted actually that now that i've put a 25w bulb in place it doesnt go off at all. Works perfectly fine. Will have it looked into. Very odd.
goings, light, strange, switches
