Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 16-02-2007, 8:43 PM   #1 (permalink)
Camera's infrared light reflecting on the window...
I bought a CCTV camera which has infrared LED lights for night vision. I want to use my camera from inside to look outside on my property through the window. It works fine during the day, but when the infrared lights come into play at night, the whole picture becomes messed up due to the double glazing window with the infrared lights reflecting all over the place, giving a useless image.
Is there anyway at all to fix this problem. Apart from putting the camera outside instead, is there anything that can be placed over the camera to stop this reflection, or is there any other sort of camera that can have night vision without using infrared lights?
Also, can anyone link me to one of these cameras where you can disguise them with a lightbulb in an outdoor light or lantern?
Thanks for your help.
kev269 is offline   Reply With Quote
Old 16-02-2007, 10:05 PM   #2 (permalink)
Thanks: Gave 2, Got 7
Re: Camera's infrared light reflecting on the window...
Not really sure about this because I have no experience in this area, but my gut feeling would be to dismantle the cam and - with some extra wiring - just place the IR outside. Shouldn't be to hard and not so easy to detect I think.
Again, no experience in this area, so this is probably a bandwith-waisting brainfart, but I am overdue for a good idea, so this might be it...
ceejay is offline   Reply With Quote
Old 16-02-2007, 10:29 PM   #3 (permalink)
not a bad idea, i wonder if this would work. I'll wait to see what other people say. Thanks.
Old 16-02-2007, 11:38 PM   #4 (permalink)
blicky_1's Avatar
Thanks: Gave 346, Got 108
Or buy an external IR unit and disconect the one in the camera.
Dedicated IR units are usually better than the ones that come in the cameras as there is more space for the LED's.
Hitachi 42PD7200|Optoma HD70|100" HCSV Screen|Onkyo TX-SR705E|B&W DM603s1 Fronts|B&W CC6s1 Centre|B&W DM601s1 Rears|Yamaha SW90 Sub|Sky HD|Dreambox 7020si + Motorised 88cm Triax Dish 53.0°E-30.0°W|Xbox|Xbox 360|PS3|Wii|PSP|DSi|Ipod Touch 32GB|Harmony One|Nikon D70s|Sony HC35|WHS|
blicky_1 is offline   Reply With Quote
Old 17-02-2007, 12:34 AM   #5 (permalink)
thanks. how would this work though? Do I point the camera from inside the house towards the same exact place position as where the IR lights are pointing? And would the lights need an extra power supply? thanks.
Old 17-02-2007, 1:54 AM   #6 (permalink)
blicky_1's Avatar
Yes point in the same direction, you would be able to see this in the dark....usually the seperate IR units come with a PSU.
Old 19-02-2007, 4:56 PM   #7 (permalink)
JagoPlasma's Avatar
Thanks: Gave 625, Got 268
move the camera right up against the glass, usually helps
if you need it to be hidden then put net curtains between the glass and camera
GAMERTAG&PSN: WilmaDicfit
Display's:50PZ80, 42PX60 & Optoma HD65 TV Source:Sky HD WD1TB Audio:SCPT560
Consoles:PS3, XBOX360, Wii
Other Stuff:iPhone 16GB, Canon 450D, Sony HDR-SR12E, Linkstation Live 1TB, WD Mybook 1TB
JagoPlasma is offline   Reply With Quote
camera, infrared, light, reflecting, window
