Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 15-02-2007, 11:33 PM   #1 (permalink)
ipace's Avatar
Thanks: Gave 44, Got 16
Question Is Varilight ok for dimming to a certain % ?
Hi Guys,
This is my first post, and to be quite honest i am extremly impressed with some setups you peple have.... i just wish i had the space/money for such a setup!
Basically i am a total newbie when it comes to home automation (was never planing it before reading about it here) I just would like to buy the most basic IR dimmer switch which is capable of dimming to a certain % of light using my Harmony 360 (stll awaiting delivery) i was looking at the Varilight range here http://www.tlc-direct.co.uk/Products/VLIQ1701.html would that do the job?
another issue i have is that the light switch is at the side of the room so basically if i setup and action to play a dvd etc....and tell it to dim the lights i am not sure if the signal reaches, in reality how good is the IR signal on these devices? does it have to be directly pointed to it??
Thanks in advance.
ipace is offline   Reply With Quote
Old 16-02-2007, 10:16 AM   #2 (permalink)
Thanks: Gave 116, Got 20
Re: Is Varilight ok for dimming to a certain % ?
First things first, welcome to the forums.
I have a couple of these switches.
In answer to your question I don't think they can be told to come on to a certain %. Although they do remember the last level setting and come on to that level again. I taught my switch to take a signal from an unused button on a tv remote. If you tap the button on the remote the light comes on to the last light level. If you hold the button the lights will dim and brighten - you then release the button when the desired level is reached.
The sensor appears to be quite responsive from acute angles, although that may just be due to the power output from the remote I am using.
Hope this helps.
Sheks
Sheks is offline   Reply With Quote
Old 16-02-2007, 10:29 AM   #3 (permalink)
ipace's Avatar
Thanks for you reply mate!
what brand do you suggest for the light switches that can take scene settings?? (on a very tight budget?)
thanks,
Ian
Old 16-02-2007, 10:40 AM   #4 (permalink)
Truth be told not sure. Looking for something similar myself - not found anything within my budget (i.e. cheap) yet.
Sheks
Old 16-02-2007, 1:25 PM   #5 (permalink)
Thanks: Gave 25, Got 109
Other than Futronix you could take a look at Leax & Mode. Both have launched 4 circuit dimmers that fit a standard single gang back box and do not require a neutral at the switch location to work. Both have IR capability and stire 4 scenes plus dim up/dim down & off. Have not seen prices so don't know if they meet your "cheap" requirement
neilball is offline   Reply With Quote
Sheks (16-02-2007)
Old 17-02-2007, 1:12 AM   #6 (permalink)
ipace's Avatar
thanks for your feedback mate however i could not find anything on ebay...any idea where i should check?
I
Old 28-02-2007, 12:20 PM   #7 (permalink)
ipace's Avatar
Just to let you know i ended up buying 2 varilight switches from ebay....waiting for delivery as i write
Old 05-03-2007, 10:08 PM   #8 (permalink)
Thanks: Gave 0, Got 2
Let us know how you go on with them, interested myself.
hardhitter is offline   Reply With Quote
Old 05-03-2007, 10:34 PM   #9 (permalink)
Thanks: Gave 3, Got 5
I looked at scene setting IR dimmers for home cinema a little while ago. There seem to be two easily available ranges. Lutron @ about £68 http://www.letsautomate.com/12115.cfm
You could try Futronix although they are more expensive. http://dimmer.co.uk/why_become.htm
square-eyes is offline   Reply With Quote
Old 05-03-2007, 11:50 PM   #10 (permalink)
Thanks: Gave 98, Got 24
word of advice, dimmers buzz which is very annoying if you can hear it...if this is for a home cinema and you're doing a proper job I would install v. low powered lights that you can turn on and off along with seperate lights
danaldinho7 is offline   Reply With Quote
dimming, varilight
