| Re: Help, Remote Controls!
They can all be controlled by a single remote. However which remote depends on what type of signals operate them.
They will be either infra-red or RF.
Infra-red needs line-of-sight (you have to be able to see the device)
whereas
RF can operate through solid objects (e.g. walls)
For the lights plugged into sockets see here : http://www.eurobatteries.com/sitepag....asp?manuf=186
You can purchase the 1 x remote + 3 x socket kit for £18.95
or you can purchase the light specific sockets which also have a dim function.
For your ceiling lights I recommend the varilight dimmer. It comes in several styles (chrome, georgian, matt chrome, white and victorian) and gangs (number of switches). Good prices here : http://www.tlc-direct.co.uk/Main_Ind...ome/index.html
Sorry I know nothing about remote control of blinds.
__________________ Kit list : Windows MCE PC, Windows XP PCs, Hitachi PJ-TX200, Yamaha RX-V2600, AE Aegis Evo 3b 5.1 speaker system, Samsumg HD950, Topfield TF5800PVR
Telewest Cable Box, Telewest Blueyonder, Xbox 360 |
