Need help with week homeseer CM12U signal
Hello.
Can anyone shed any light on a problem i'm having with my X10 CM12U. I have Homeseer. When I send an X10 (homeseer) signal from my PC via the CM12U, the signals seem to be very week in that it switches some sockets (around the house), some seem hit and miss, and some don't work at all. Some have worked and now don't. It is like the signal is only just strong enough that it just about reaches some sockets but falls short of the mark on others.
I have tried connecting by usb and serial port using a usb/serial port converter but this doesn't make any difference
Have you any idea what might cause this problem or can you recommend anything i can do to test or remedy the problem.
Any help would be greatly appreciated.
Cheers,
Chris
