Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 17-07-2006, 7:45 AM   #1 (permalink)
Thanks: Gave 1, Got 0
X10 Project....Help!!!
Just bought a new house and want to install a security sytem along with automating various features. I also want to try and controll most of the stuff using an all in one remote and maybe my pc.
X10 seems to be the way forward (if im wrong please let me know).
I have rather a tight budget and want to install a nice simple alarm system first which i can then tie into automating other features in my home.
The two systems that seem to stand out are Marmitek safe gaurd and Visonic powermax
Any help would be greatly appreciated.
actionorton is offline   Reply With Quote
Old 18-07-2006, 6:05 PM   #2 (permalink)
Docta teef's Avatar
Thanks: Gave 30, Got 19
If you go to www.letsautomate.com they have x10 alarm systems.
Docta teef is offline   Reply With Quote
Old 24-07-2006, 6:21 PM   #3 (permalink)
Marlin
Posts: n/a
I control most of the home lights using X-10 modules from my PC, which runs an excellent piece of software called HomeSeer. I use it to make the house look lived-in when I'm at work or away on holiday.
I bought most of the modules from letsautomate, and the software I downloaded from HomeSeer's website.
projecthelp, x10
