Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 15-07-2006, 10:41 AM   #1 (permalink)
jono400
Posts: n/a
White out probs with security cam
Have one off these Aldi surveillance cameras with the built in PIR movement sensor and two way intercomm facility whith which I am more than happy with the only problem is that the camera picture keeps getting " white out " it does mention within the handbook supplied with the camera that car headlights can trigger this sympton but just to switch off and back on again to cure the problem.
now where I have my camera situated overlooking the front door off the house there is no chance off car headlights !!! so just whate else is causing this white out problem and how do I cure it ?? switching the cam off and then back on again is not really feasable every time.
anyone got the same problem managed to cure this problem ??
Old 19-07-2006, 11:13 PM   #2 (permalink)
jono400
Posts: n/a
Anyone ??
Old 20-07-2006, 9:11 AM   #3 (permalink)
vex
Assured Advertiser
Thanks: Gave 9, Got 181
If they mention that head lights can do it then any bright light source with cause it.
Does the sun hit it at any time?
vex is offline   Reply With Quote
Old 20-07-2006, 7:51 PM   #4 (permalink)
jono400
Posts: n/a
Thanks mate, thinking about it its actually causing the picture to darken to the extent that the picture is very hard to see, a quick off and then back on again cures the problem but still sure thats its something like the actual lens seeing too much sunlight, after titled the camera so that there is infact very little actual light getting to the camera but still getting the problem ????!!!!!
Old 03-08-2006, 3:52 PM   #5 (permalink)
Do you have any spec sheets on the camera?
Kind regards
Alan
akcctv is offline   Reply With Quote
cam, probs, security, white
