10-07-2006, 8:40 PM
#1 (permalink)
| | Member
Thanks: Gave 1, Got 3 | Celing fan control using X10
I am a complete novice on the topic of X10 but have done some reading on the topic and keen to give it a try. It just so happens we are looking to install a ceiling fan (which also has a light) in one of our bedrooms....is it possible to have the ceiling fan and light controlled using X10? I know that some models of ceiling fan come with a remote control but since I would be looking to use X10 more extensively I would prefer to go down that route.
Thoughts anyone?
__________________ HTPC: Silverstone LC03V Case, MSI K8N Neo4, AMD 64 3000+, PCI-E Gigabyte 6600GT, 200 gig Seagate Barracuda SATA, Aerocool front panel, NEC Dual Layer DVD TV: Panasonic PHD8, Sharp Aquos 26LC03 LCD AMP: Denon AVR4306 Speakers: Bose Acoustimass 10 surround sound, Music Streamer: Sonos |
11-07-2006, 7:37 AM
#2 (permalink)
| | Senior Member
Thanks: Gave 236, Got 148 |
Are the fan and light wired separately, or is it one connection?
Can you show the wiring diagram, or a link online to your product.
11-07-2006, 1:05 PM
#3 (permalink)
| | Member
It is the Mayfair Polished Brass from this company...(under "42 to 46 inch fans") http://www.ceilingfanstore.co.uk/
With the 82 Saturn globe light kit (under "Globe Light Kits")
I presume the light switch is seperate as it is in kit form which can be added to the fan seperately.
11-07-2006, 2:21 PM
#4 (permalink)
| | Senior Member
You can use x10 on these bits of kit.
You need to bear in mind that the fan will be bi-directional, but x10 will only
control the supply to it, not the direction. This will still have to be altered at
the fan itself.
The light will take its power from the fan too. That means you will not have separate control of fan and light unless you alter the wiring in the rose of the
fan.(assuming all the wiring is done in the rose).
Basically, if you leave the switches on the fan, in the on position, then you
can control remotely with x10. Otherwise, for separate control you will have to
modify the internal wiring of the equipment if it is accessible.
Hope that makes sense mate.
11-07-2006, 6:15 PM
#5 (permalink)
| | Member
Yes this makes sense. The part which is not ideal is that the light and fan will not be seperately controllable without digging into the wiring...I had intended on using this in the baby room so I wanted to be able to turn the light off but keep the fan running (an perhaps even have a timer such that the fan turns off at a set time).
If I did use it what X10 units would I need to buy (remember I am a complete novice!)
12-07-2006, 7:43 AM
#6 (permalink)
| | Senior Member
Thanks: Gave 236, Got 148 | THIS will do the job mate.
Assuming you can get access above the fan light. Mount it on a joist local to the
fan and connect up.
12-07-2006, 7:49 AM
#7 (permalink)
| | Senior Member
If you can actually get at the internal wiring of the Fan/Light, then you can use THIS unit for on/off/dimming of the light too.
