Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 30-06-2006, 7:32 PM   #1 (permalink)
Thanks: Gave 6, Got 0
Cooling advice required
I have the following equipment on a storage rack in a cupboard:
Russound CAV6.6
Russound SMS 3 Server
2 x Sky+ boxes
1 x DVD Player
I have 2 vents cut into the door for airflow, but the cupboard is still very warm.
Does anyone have any ideas on how to keep the cupboard space cool ?
There is a light bulb above the units (which is never on) my installer mentioned a few weeks ago about some type of small fan that plugged into the light bulb rose ?????
I did think about a laptop cooling pad under the CAV6.6 as this is the hottest piece of kit.
Any ideas most welcome
sirees is offline   Reply With Quote
Old 01-07-2006, 3:41 PM   #2 (permalink)
Thanks: Gave 1, Got 5
a fan inside the cupboard would help move the air, but it would still be warm, best bet would be too fix 1 or more small pc fans over the top vent, blowing out of the cupboard, this would then allow cooler air in the bottom vent, you would need a regulated 12v power supply to connect the fan too and just leave that plugged in. I no you can get pc fans in 80mm and 120mm so you may be able to get a few of these running. You could also fix one to the bottom to suck air in as this will also help.
rssteve is offline   Reply With Quote
advice, cooling, required
