25-06-2006, 2:14 PM
#1 (permalink)
| | Veteran Member
Thanks: Gave 188, Got 700 | Neon Lighting You may of seen 'chav boy racers' with stupid lights on the bottom of their cars, but i recently found out that they have them on the inside as well, something like this: http://www.solware.co.uk/customise-c...on-tubes.shtml
Now i'll get to my point, i've several members home cinema pictures and some of the have lights behind the plasma, stand, speakers of whatever but for the price that some of paid it seem a little steep, so would these one designed to be used in a car work? They all seem to power via a car cigarette lighter thingy, so you it be a case of cutting that off and fitting a normal UK plug or am i being hopelessly optimistic
__________________ | Panasonic 42PX60 | Panasonic DMP-BD30 | Pioneer VSX-LX50 | Xbox360 HD-DVD | Kef Q's |
| The Cake Is A Lie|How my achievements mock me! - Bill Shakespeare |
25-06-2006, 3:17 PM
#2 (permalink)
| | Member
Thanks: Gave 1, Got 5 |
Hello my first post on here. I also thought about this some time ago, the problem is finding a power supply that matches the lights you want to use. I just brought a set of ebay from here, and they have worked perfectly for over 6 months now. http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE%3AIT&rd=1 |
25-06-2006, 3:59 PM
#3 (permalink)
| | Veteran Member
Thanks: Gave 188, Got 700 | ^cheers for that link steve, they look pretty good. Good value as well it looks too
25-06-2006, 4:45 PM
#4 (permalink)
| | Member
yeah i have the blue they are nice and bright, worth a g if not.
26-06-2006, 8:52 PM
#5 (permalink)
| | Member
Thanks: Gave 23, Got 26 |
You might want to have a look here......... Neon-Lights.co.uk
__________________ My Kit - Toshiba 46XF355DB - Onkyo TX-SR606 - Tannoy SFX 7.1 - Crystal Xbox 200GB - Xbox 360 Elite - 320gb PS3 - Wii - Toshiba HD-EP35 - Panasonic DMP-BD35 - Sky HD - Harmony 525 - HTPC - HDX 1000 Media Tank |
28-06-2006, 2:26 PM
#6 (permalink)
| | Member
Thanks: Gave 160, Got 116 |
Yep, I can vouch for the fact that the in-car tubes will work just as well. All you need is a standard 240VAC -> 12V DC adapter that can be bought in any electrical store.
These are quite cheap too.
2 x 12" cold cathode tubes, complete with 12V adapters. http://cgi.ebay.co.uk/IN-HOUSE-BLUE-...QQcmdZViewItem |
29-06-2006, 12:04 AM
#7 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | neon lighting
you may want to try this link www.litewave .co.uk they are led not neon but offer a full range of products to suit any situation multi colour can be programed + sound reactive. I used them to do the home cinema shown on their home page
30-06-2006, 11:54 AM
#8 (permalink)
| | Member
Thanks: Gave 6, Got 20 | Quote: |
Originally Posted by Pooon They all seem to power via a car cigarette lighter thingy, so you it be a case of cutting that off and fitting a normal UK plug or am i being hopelessly optimistic | DON'T DO THAT. Car = 12volts DC, mains = 240volts AC.
Unless you want a firework display and possibly a visit from a big red vehicle with blue lights on top.
A 12V mains adapter is required, as noted in another post above.
AVR300+P90/MA GR20+GRC/M5ds/StrataIII,
PT AE3000, Beamax 293cm diag 2.35:1 M-series screen, BDP550, Arcam CD93, Harmony 1000 RC
