25-06-2006, 10:19 AM
#1 (permalink)
| | Member
Thanks: Gave 1, Got 8 | CCTV setup
I am looking into replacing my cctv camera which i bought about 7 years ago.
I am looking for a camera-
For outdoor use
With good night vision
Clear picture at upto 40 feet
With sound
Also would like something to record onto with good picture quality,but camera is main priority.The cheaper the better.
ps.Prefer not to go the pc route or wireless.
23-07-2006, 9:34 AM
#2 (permalink)
| | Member
Anyone??
23-07-2006, 12:22 PM
#3 (permalink)
| | Member
Thanks: Gave 14, Got 30 |
I assume you are looking at replacing a camera on a property, and not a commercial building?
As you are using the camera outside, I would recommend one that is at least IP54 rated, however IP66 or greater would be preferable.
As you are looking after good nighttime use, you should be looking at day/night (colour/mono) cameras. The mono aspect allows you to use a suitable IR illuminator to discretely illuminate the scene, be it an external unit or an integral unit. LED illuminators are starting to provide reasonable performance, plus also have the added benefit of reduce maintenance and running costs.
The minimum resolution you want to be looking at is 480 lines in colour and 570 lines in monochrome, although cameras are starting to appear at the lower end of the market in higher resolutions e.g. 500 lines colour, 580 lines monochrome.
Sound is the awkward request; most cameras do not provide this, and most certainly do not at the medium to high-end range. You could purchase a separate microphone board, but personally I wouldn’t bother as they severe little use.
I also believe you are taking the correct stance with not wanting to go the PC route for recording. IMO standalone DVR’s are far superior to the PC based models for most applications (other than very large sites).
You could try taking a look at a few of these sites, which provide reasonable CCTV equipment for the low end of the market. I generally prefer the vandal resistant dome type models for domestic installations, as they are a little more discrete without looking Mickey Mouse: http://www.rfconcepts.co.uk/cctv.htm http://www.henrys.co.uk/cctv.htm http://www.ezcctv.com/index.html http://www.digitalvideos.co.uk/ http://www.iviewcameras.co.uk/
At the professional end the following: http://www.sovereigncctv.co.uk/ http://www.norbain.com/ |
23-07-2006, 12:26 PM
#4 (permalink)
| | Assured Advertiser
Join Date: Dec 2001 Location: Where ever you want me to be.
Thanks: Gave 95, Got 1,332 |
are you prepared to replace the wiring or do you want to stick with existing (coax?) you can get HDD based recorders with 4 inputs (basically a Quad processor with HDD recording for £160 ish (+HDD) it depends alot on the situation and how discrete/overt you want the CCTV to be
24-07-2006, 10:26 AM
#5 (permalink)
| | Member
Thanks: Gave 1, Got 8 | @ZippyCat
Yes i am looking at replacing a camera on a property.I still want to have the sound function and would be greatfull for any info on how this can be done with the use of a seperate camera.Thanks for the links i will take a look. @hornydragon
I am prepared to replace the wiring if needs be.I would like the idea of a HDD based recorder but i can only seem to find ones for multiple cameras,which would be wasted as i only need the input for one.
24-07-2006, 10:47 AM
#6 (permalink)
| | Assured Advertiser
I think they are as cheap to make with 4 inputs as one (much more popular) you could go for one with 4 inputs and then use 1 day camera and a seperate night one better results but higher cost
24-07-2006, 12:17 PM
#7 (permalink)
| | Member
I must say I wouldn’t go the two camera route myself; you are much better off going with a decent standalone day/night camera.
On the audio side of things, try searching for PCB audio boards which can often be mounted within enclosures, or alternatively you could try: http://www.henrys.co.uk/cctv/mpa12.htm
There are also some cameras which incorporate audio boards such as: http://www.henrys.co.uk/cctv/guardian.htm http://www.henrys.co.uk/cctv/colourircamera.htm
However as I said above, cameras with integral audio tend to be at the entry level, and I wouldn’t recommend either of the above cameras for decent picture quality. Ultimately you end up compromising the picture quality for the feature of audio. On the recording side of things, most low end DVR’s offer a single channel input for audio recording. Please note that the playback of audio from DVR’s can often be sporadic, as DVR processors tend to prioritise picture over audio i.e. periods where sudden movement is detected, audio drop out is frequently experienced.
25-07-2006, 8:12 AM
#8 (permalink)
| | Member
Thanks: Gave 1, Got 8 | @hornydragon
I would prefer to just have one camera.Are all the 4 input ones the same or should i be looking for a certain type? @ZippyCat
I am now looking for a decent standalone day/night camera as you suggest.Thanks for the links you posted the first one(Microphone) looks like a poosiblity but just wondering how it connects to the power supply,but the second one needs extra lighting and the third is not suitable for where i need it outside.I am undecided on what to go for now as i would really like to have sound aswell as good picture.Are DVR processors intended for short use or can they be used for continous recording?Would i be better getting a dvr or just a hdd recorder?
25-07-2006, 11:55 AM
#9 (permalink)
| | Member
One important difference between domestic and CCTV recording equipment is that CCTV equipment is designed to run around the clock for 365 days a year. I you use a cheap VCR unit for example, I guarantee the unit would become faulty within a month or so, not to mention the constant change of tapes i.e. 3 times daily. Providing you buy a purpose made DVR unit, you should have no problems whatsoever.
26-07-2006, 9:07 AM
#10 (permalink)
| | Member
Do DVR units run constantly? Also would this be the same with hdd recorders?
26-07-2006, 11:42 AM
#11 (permalink)
| | Member
Go with a dedicated DVR unit, PVR’s are not suitable for a number of reasons including reliability & compliance with the DPA.
26-07-2006, 11:46 AM
#12 (permalink)
| | Member
Opps I didn’t answer the first question; DVR’s do run continuously, however it is possible to configure them to only record upon detection of movement. The best type of configuration is a slower frame rate when no motion is detected, and an increased frame rate upon detection of movement to conserve memory.
27-07-2006, 8:29 AM
#13 (permalink)
| | Member
I need something that will record constantly and be able to output through coax as in aerial to tv.Can you suggest something along these lines if there is one?
27-07-2006, 9:05 AM
#14 (permalink)
| | Guest | http://www.rfconcepts.co.uk/digital-recorder.htm
The R200 is first class,i've fitted a few and had no problems.
As Zippy says best to set it up for motion detection on a high frame rate,then your not wasting hdd space.
They are configurable on motion etc, so you can set the sensitivity and also mask areas off so when the wind blows trees/plants it will not record.
You can also add an external usd hdd to give you a bit extra , probaly 4/5 weeks of recording depending on activity.
All dvr's will work with a coax lead to your monitor, you will just have to terminate the cable suitable,normally bnc or rca which can be done using "f" connectors .
Camera's can be a minefield, on the RF concepts page have a look at the CC70 camera,these are really good and will see in total darkness, again as zippy mentions they have built in ir which can attract spiders webs but its only a wipe with a feather duster now and again.Even if they are mounted high,just tie it to a stick... | |
27-07-2006, 12:05 PM
#15 (permalink)
| | Member
In general standard CCTV cameras & DVR’s output composite video feeds which can either be plugged directly into you TV via the appropriate adapter (RCA or SCART), or can be converting to RF frequencies through an ‘RF Modulator’. If for example you have an aerial loft box for your TV distribution, it would be prudent to feed the CCTV through this via an RF Modulator, so that each TV connected on the network is capable of tuning into the CCTV. In terms of overall picture quality, composite video feeds will be far superior to that of RF; as is always the case with AV. In my house I have a mixture of both whereby the dedicated CCTV monitors are connected to the composite video feeds, and the televisions are connected to the RF feeds via my loft box.
