Hi there,
Does anyone know of anything that will turn on my mains voltage ceiling lights when i walk into a room.
I have seen this link http://www.alan-parekh.com/stair_lights.html that turns on low voltage LED lights, and wondered if you can get the same sort of thing that turns on mains voltage lights.
The wiring will not be a problem, as basically we are ripping all the old stuff down and putting up new, so I will be able to drill through my stud wall joists to accommodate the necessary wiring.
Standard PIR, fit it in line with lighting switch... or on a fused spur...
I have to confes not to having used this one, but I imagine it can't be too tricky... as long as you're happy working with mains, otherwise get a sparky to fit it... If it's in a bathroom or Kitchen, then I think in England you need to satisfy new building regs (p)...
I've looked at the product manual and doesnt look difficult to wire in, (im 15, have done quite a bit of re-wiring, plug sockets, 2-way lighting cirucits that sort of thing, but im certainly no pro)
Cheers for replying, should do the job perfectly.
