Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 05-06-2006, 2:34 PM   #1 (permalink)
owain_thomas's Avatar
Thanks: Gave 56, Got 54
Rako for table lamps?
I'm interested in getting a rako setup when (if!) we move, how do you use the dimming modules with things like table lamps? do they fit in the wall or are they on display?
flickr
HC - Rotel RSP-1068 Processor, Mac Mini running Plex, Arcam A90, Totem Arro Speakers
TV - Panasonic TH42PHD8 with Lumagen HDP
owain_thomas is offline   Reply With Quote
Old 05-06-2006, 3:13 PM   #2 (permalink)
Pop up Dragon's Avatar
Thanks: Gave 7, Got 18
The Rako line units are the same as the in ceiling ones other than the antena is on the inside.These can be mounted any whre inline .
Pop up Dragon is offline   Reply With Quote
Old 05-06-2006, 3:22 PM   #3 (permalink)
thanks for the reply,
does that mean you would sick them in the wall, say behind a faceplate and have the lamp wired through the faceplate? do some people have them "on display" if you like, ie not buried somewhere?
I'm a bit confused how it'd work in real life so if any one has some examples they could share (pictures would be great but a description will do!) I'd appreciate it.
flickr
Old 05-06-2006, 3:34 PM   #4 (permalink)
I have mine inline mounted close to the lamps then fitted under the tables(great for wood not so great for glass).Because they are dark in colour they dont stand out and you can normally find some place to hide them.I wouldn't recomend fixing them in wall as if you ever need to change then it might be a bit of a problem.
Old 05-06-2006, 4:33 PM   #5 (permalink)
vex
Assured Advertiser
Thanks: Gave 9, Got 181
Rako make two versions of their RDL250 and RDL500's. The 'C' is designed for hiding in the ceiling and the L version is the in-line vesion, in black with no external antenna.
These just sit in line on the power cord feeding the table lamps.
We have some demo ones we built up here with a plug on one end and a socket on the other, allowing us to plug into any light and control it.
Chris
vex is offline   Reply With Quote
Old 08-06-2006, 2:00 PM   #6 (permalink)
Ahhh, the penny just dropped! so these just go on the power cord like, for example, a switch on a lamp's cord might? Now I get it... sorry for being thick, thanks for the replies.
For some reason I thought they needed hiding somewhere like the ceiling ones.
flickr
Old 09-06-2006, 11:40 AM   #7 (permalink)
owain
the in line and the ceiling come in the same case,as do most other Rako modules.the external antena is said to help with longer distances from keypad to dimming unit,for long runs you can add a booster(Rab100).they now also do a rack unit that will control i think up to 4 ccts to a 300w max(not sure about this best to check if its what you are looking for)
lamps, rako, table
