Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 04-05-2006, 10:11 PM   #1 (permalink)
Spy
Spy's Avatar
Thanks: Gave 19, Got 60
Question Rako Install Q
I wonder if anyone can help.
I would like to install 4 circuits of downlights with 4 RAKO dimmer modules to control each circuit.
Typically, the dimmer module is installed at the end of the circuit (where you would expect the light switch).
Is it possible to continue the wiring after the dimmer module, to a traditional 4 channel light switch ?
Would I then be able to use the light switch as a master on/off for each circuit ?
For example, when a circuit is switched off from the traditional switch, the Rako dimmer will not work and vice-versa.
Or is this not recommended and may damage the dimmer module ?
Thanks for your help.
AV: Samsung 50Q7HD, Marantz SR8001, Windows MCE PC, Toshiba HD-XA1, PS3, Gallo Diva/Micro, Velodyne DD15
HiFi: Nad 3020i, Rega Planar 2, Nad C521BEE, Denon TU260L Mk II, Mission 71i, Atacama SE24 stands, Sonos multi-room
Spy is offline   Reply With Quote
Old 05-05-2006, 8:15 AM   #2 (permalink)
Thanks: Gave 1, Got 13
I cant see any reason why this wouldn't work. I dont believe you will damage the dimmers at all and you can set them up to be on when powered up.
I cant really see the point though - why not just use one of their wall mounted RF switches to do the same? How are you planning on controlling the dimmers if not by one of their switches?
Dave
DaveChester is offline   Reply With Quote
Old 05-05-2006, 11:43 AM   #3 (permalink)
Spy
Spy's Avatar
Talking
Thanks Dave.
I will be using one of the RAKO wireless controllers and realise this provides the same function.
I guess my real reason is to have teh wiring going back to a traditional light switch in case I need to change the system in the future. If I terminate the wires at the dimmer pack in the ceiling, then it will be a big job later should I wish to utilise a wired wall switch.
I am thinking of hiding the traditional switch somewhere unobtrusive.
Old 06-05-2006, 11:04 AM   #4 (permalink)
Thanks Dave.
Why not wire in the traditional way but instead of putting a switch on the wall scotch block the wires together and put your Rako switch over the top?? Easy to back track then.
Old 06-05-2006, 1:19 PM   #5 (permalink)
Spy
Spy's Avatar
Thanks Dave, that's a good idea, I will definitely consider it.
Old 02-06-2006, 12:07 AM   #6 (permalink)
rako system
spy.
i have a rako system if you switch off the supply to the dimmers ie turn off the light switch, when you switch it back on all those dimmers fed from that switch will turn on in full mode not dimmed as such would this cause you a problem ?.there is really no need for a switch.just crimp thru your feeds and switch lines at switches and install a rako switch plate over the old switch box or buy a 7 button remote. ( you dont need both unless you got kids and they chuck the remote down the toilet)well handy.
sparkey-chris is offline   Reply With Quote
Old 05-06-2006, 11:40 AM   #7 (permalink)
vex
Assured Advertiser
Thanks: Gave 9, Got 181
Just a quick note:
The Rako software allows you to change how the dimmers re-act when the power is turned on. IIRC this can be set to 'not come on' - 'return to the last setting' or 'come on full'
vex is offline   Reply With Quote
Old 05-06-2006, 7:11 PM   #8 (permalink)
Spy
Spy's Avatar
Thumbs up
Thanks for the responses guys
I have decided to not wire in a switch and just terminatre the wires for the future.
Old 06-07-2006, 8:33 PM   #9 (permalink)
You may want to look at a new Rako product announced a couple of weeks ago, it's called the PILL and is designed to be installed in the wall light switch box and the only wiring needed is the switched live to pass through it, more like a standard dimmer switch. You can then either fit a rako control plate/remote or an on/off raise lower wired switch into the PILL. I've attached the Rako product sheet for this.
I'll be using some of these PILLs in places where installing a ceiling dimmer module is difficult or costly
jmwhooper is offline   Reply With Quote
Old 18-07-2006, 1:09 PM   #10 (permalink)
Thanks: Gave 1, Got 0
Do you know how much these cost?
X10 have a similar product, without the need for a neutral. Can the RAKO wall mounted controllers recall more scenes than the buttons? And if I have a number of these controllers, can each of these recall different scenes?
MRadja is offline   Reply With Quote
Old 18-07-2006, 3:34 PM   #11 (permalink)
vex
Assured Advertiser
Typically, Rako costs about £100 per circuit and per controller.
Rakos keypads offer upto 4 different scenes, an off and a 'scene dim up/down' and finally yes with additional controllers set to different rooms you can recall a completely different set of scenes and ciruits.
Chris
install, rako
