Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 27-04-2006, 3:14 PM   #1 (permalink)
mysticsniper's Avatar
Thanks: Gave 0, Got 5
Which alarm System
Hi there everyone,
I am just about to move into my first house. I am going to buy myself an alarm system, but I am unsure of which system to buy. I have seen a selection of systems with similar prices, but most of them have the same amount of equipment, but I don't know enough to know which is a good system compared to a bad one
The systems are:
Visonic PowerMax+ Wireless 3 Room Alarm Kit
YALE P-FAKIT5 Wirefree alarm kit
SA5MK Response Wireless Alarm System
BT Home monitor VP1000 System
If you have any other better systems, I would like to hear about them as well.
TIA
mysticsniper is offline   Reply With Quote
Old 27-04-2006, 3:27 PM   #2 (permalink)
fabbers's Avatar
Thanks: Gave 1, Got 8
I'm going through the same conundrum at the moment, i'm swaying towards the BT Home monitor VP1000 System at the moment as it seems a good system and can be had for £82 from savastore, the only downside is there's no bell box but these can be purchased from eBay for about £80.
fabbers is offline   Reply With Quote
Old 27-04-2006, 5:16 PM   #3 (permalink)
JohnS's Avatar
Thanks: Gave 6, Got 21
The BT one is just a rebadged Powermax, they are better than the yale or response ones but are both very much inferior to the stuff the pros use. Poor wireless is extremley poor and unreliable.
Pick a SSAIB or NACOSS installer and get a quote. I use the Scantronic hybrid stuff or Rokinet /Guardner Technolgy depending on the type of install.
John
VW60, 10ft Screen Excellence Acoustic, Kef Ci9000 fronts and centre, Ci200r rears, Myryad MDP500G6, Arcam P7, SVS Sub, SMS, HTPC, Pronto 3*TSU9400, RFX9600, Russound Multiroom, Squeezebox Duet
JohnS is offline   Reply With Quote
Old 27-04-2006, 5:42 PM   #4 (permalink)
Thanks for that, but I think that my house won't be targetted by any pro's as I am moving into a 2up 2 down Terraced house, and nothing fancy. That's why I am going for something cheaper and will be a deterrant more than anything else
"Knowledge is only limited to the restraints we impose on ourselves."
-G.G
Old 27-04-2006, 5:57 PM   #5 (permalink)
Thanks: Gave 3, Got 26
Great ..........what was the address?
TagMclaren DVD32FLR TAg AV32Rbp+psm Tag 100x5 power amp, Wilson Benesch Arcs, Tag Calliope centre. Velodyne CH10T sub, Loewe Connect 42+DR TV
davee is offline   Reply With Quote
Old 28-04-2006, 12:08 PM   #6 (permalink)
Thanks: Gave 14, Got 30
Most insurance companies will not recognise a DIY alarm system as qualification for a reduction in your premiums. The police will also not attend if your alarm system detects an intruder and would therefore require an eyewitness to confirm somebody is within your house. If you’re after a deterrent then why not just purchase a pair of dummy ADT bell boxes from Ebay, they would give the impression of a monitored alarm system. There not exactly my favourite security specialists, however there is no denial that they are the most recognised, which should act as a good deterrent to deter opportunists.
ZippyCat is offline   Reply With Quote
Old 02-05-2006, 7:55 PM   #7 (permalink)
blicky_1's Avatar
Thanks: Gave 346, Got 108
Nacoss systems can start from £375 fitted with cert. if you shop around
Hitachi 42PD7200|Optoma HD70|100" HCSV Screen|Onkyo TX-SR705E|B&W DM603s1 Fronts|B&W CC6s1 Centre|B&W DM601s1 Rears|Yamaha SW90 Sub|Sky HD|Dreambox 7020si + Motorised 88cm Triax Dish 53.0°E-30.0°W|Xbox|Xbox 360|PS3|Wii|PSP|DSi|Ipod Touch 32GB|Harmony One|Nikon D70s|Sony HC35|WHS|
blicky_1 is offline   Reply With Quote
Old 04-05-2006, 5:12 PM   #8 (permalink)
Any chance of a linky m8
-G.G
Old 04-05-2006, 8:00 PM   #9 (permalink)
You won’t find any reputable security company advertising prices on the web, as all installations should be subject to a site survey/risk assessment. Your best bet would be to look through the Yellow Pages for intruder alarm specialists who are NACOSS (NSI) Silver/Gold or SSAIB approved. They will do a risk assessment of your property, select the appropriate equipment and issue you with a formal quotation. The figure quoted above is certainly achievable for a small, non-monitored bell only installation; however do not only go on price.
Old 04-05-2006, 9:15 PM   #10 (permalink)
blicky_1's Avatar
Just contact you local Nacoss/NSI company and ask, we advertise at the £375 starting price for a small bells only system but do not sell that many as most situations require more kit. As stated above there is no average price as you need to see the property first to survey/risk assess.
Old 05-05-2006, 2:52 PM   #11 (permalink)
Thanks: Gave 40, Got 33
you can get a pro quality bellbox for around £30 straight from the suppliers like alarm supplies or gardner technology. (PS I am an Alarm Service Engineer, the website the security installer will help you track down suppliers in your area, and the mass of pros that frequent the forums on their will generally be helpfull with any problems you have as will I where I can on here.)
Pioneer DV-515, Pioneer DV-575A-Sil, Sony KV32FX60u, Sony BDP-S350, Sony KDL-40W4500, Yamaha HTR-5540RDS, Gale Centre 1, Paradigm Titan (FS), Paradigm PDR-10 Sub, KLH 970A (RS), Optoma HD-65, Nintendo Wii
Wii Code = 2051 5972 0806 3746
sy278 is offline   Reply With Quote
Old 05-05-2006, 4:06 PM   #12 (permalink)
The only problem with the BT system is that it is a wireless system, so it may be difficult to integrate a wired self-actuating siren. I know some wireless systems do provide this facility, but as far as I’m aware the BT system does not.
Blicky 1, I hope I did not offend you with my comments above, I just wanted to point out it’s not a simple as finding a security company that advertising prices for a complete system under the pretence of one size fits all.
Old 05-05-2006, 5:42 PM   #13 (permalink)
blicky_1's Avatar
No problem mate no offence taken......
I agree with what you say about companys who advertising fixed prices when they have not even seen the property, this is why we say 'start at £375' even though it is just possible to fit one for £375 to a small property (but not much profit!)
Old 08-05-2006, 10:13 PM   #14 (permalink)
Depends on what you want
There are alarms to suite all needs it seems. For me i have a really small apt so I bought the protector plus from X10 (http://www.x10securitysystems.com) it is inexpensive and works with my existing phone line to call 4 emergency contacts of my choice. It was easy to setup and hasn't let me down yet.
Tom Taylor is offline   Reply With Quote
Old 09-05-2006, 10:57 AM   #15 (permalink)
Thanks: Gave 1, Got 9
Tom
It looks quite good but I assume that it only works in the US?
dobbin is offline   Reply With Quote
alarm, system
