23-04-2006, 10:42 PM
#1 (permalink)
| | Member
Thanks: Gave 8, Got 0 | 1000W dimmer switch
Is it possible to get 1000watt dimmer switch, needed for 6-7 mains downlights
Thanks in advance.
__________________ Pioneer 656A,JM Labs Cobalt 816,JM Labs Cobalt CC800,Primare A30.5,Rotel RSP-1068, Sony speakers(rear),Chord Odyssey 2,VDH D102 MkIII. |
24-04-2006, 10:26 PM
#2 (permalink)
| | New Member
Thanks: Gave 0, Got 0 |
most downlights are 20, 35, or 50w 6 or 7 would only be 300-350.....they are not normally 100+ watts, for a good reason, they are set in the ceiling, so the heat is massive.
Darren
25-04-2006, 5:54 PM
#3 (permalink)
| | Member
Thanks: Gave 3, Got 26 |
What exactly are you trying to dim. 1000w/7 = 150w approx. Linear halogen?
__________________ TagMclaren DVD32FLR TAg AV32Rbp+psm Tag 100x5 power amp, Wilson Benesch Arcs, Tag Calliope centre. Velodyne CH10T sub, Loewe Connect 42+DR TV |
25-04-2006, 9:55 PM
#4 (permalink)
| | Member
start a niteclub
10-05-2006, 10:19 AM
#5 (permalink)
| | Guest |
Rako do a 1200w dimming module, due to its form factor though it won't fit through the hole normally made for a downlighter, it would ordinarily be located remotely.
30-06-2006, 12:08 PM
#6 (permalink)
| | Member
Thanks: Gave 6, Got 20 |
I have two 2000W dimmer switches from Superswitch - used for dimming 500 floods. You can't fit them in a normal pattress box though
AVR300+P90/MA GR20+GRC/M5ds/StrataIII,
PT AE3000, Beamax 293cm diag 2.35:1 M-series screen, BDP550, Arcam CD93, Harmony 1000 RC
