Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 21-04-2006, 10:01 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Leds
Hi does anyone know where i can buy LED strips to place under my tv stand as its nearly complete and i need these to add teh finishing touch hopfully i could use battery powered ones however they are mains plugs beside the stand so either optionis availble for me!im 16 and this is my first real project it will look great thanks guys i would also liek a cheap set if possible as money is running dry now lol
gaz06 is offline   Reply With Quote
Old 21-04-2006, 10:58 PM   #2 (permalink)
pixelpidgeon's Avatar
Thanks: Gave 165, Got 107
Hi gaz. Have you tried ikea. ive read on this forum they sell some good striplights, maybe this isnt the same as what your afeter. maybe it is.? could be worth you a search?
cheers, pixel
Fluker
"It aint possible to live unless you crossing somebody's line..."
pixelpidgeon is offline   Reply With Quote
Old 22-04-2006, 11:41 PM   #3 (permalink)
Thanks: Gave 1, Got 9
Yeah
Is this what you are after.
They work very well and you can join them together.
http://www.ikea.com/webapp/wcs/store...79*15748*16082
dobbin is offline   Reply With Quote
leds
