First "asking for help" post, so go easy on me ...
Some months ago we moved into our Victorian house and now has come the time when I’m able to get one of the Upstairs Bedrooms modernised and redecorated and hopefully turn it into a bit of a Home Cinema/Gaming room, all signed and sealed with the Mrs’ Permission of course
Thing is I have a Builder starting work next week on this room as well as other parts of the house and I haven’t a clue about the Lighting I need for the cinema room, I have had the quote done from the Builder with the Ceiling being plastered and Downlighters fitted included, so now I just need to find the Lights I want and the Dimmer switch also.
Being a complete Noob on anything Lighting or Electrics based I don’t know what type I should get nor how many lights I will need for this sized room.
So I thought as with most posts asking for help, it might be easier if I posted on here what I would like for the room to have, and then maybe make it simpler for someone to advise me on which actual products to buy rather than you folks guessing what I might want.
Okay the room is about 12’ x 11’ and the Ceiling is 10’ high, it has a chimney breast wall down one side with 2 Alcoves either side, it doesn’t have lots of natural light in the daytime or early evening due to the window being North facing.
I would like the Light in this room to have a bit of warmth to it and not be too cold or clinical, if that is possible with Downlighters ?
The only other main thing I can think of is, I would like the lights to be dimmable and be able to use them with a remote dimmer that wont buzz.
I would appreciate any guidance or suggestions on this, hope you can help me out.
Thanks Guys
