| Lutron Grafikeye wiring problem: help [ls
Hello,
I've got a 6 circuit Grafikeye in my garden house. It's linked to a "slave" panel in the house (30m away). The electrician wired it with CAT5 cable (which is too thin according to Lutron manual, it needs 18AWG minimum but works fine in the house as the runs are much shorter). I fiddled around with it by paralleling some wires (the electrician used 4 out of the 8 cores only) and it worked for a while. Now it's dead again.
Has anyone got any idea how this can be fixed? I'm very puzzled by the fact that it worked intermittently. It should either work or not.
