Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 22-07-2005, 1:05 PM   #1 (permalink)
helpneeded
Posts: n/a
LED Shelf Lighting
Hey folks, could do with your help.
I've purchased a 5 tier glass-shelf bookcase. I now want to purchase some blue LED lights which I can mount to the rear edge of each glass shelf, so the light shines through the shelf, making it glow.
I've seen the same principle in Woolworths, in the Electronics section, and also in the Discovery Store (similar to the Gadget Store), before they closed down.
I know I could 'build' something myself, but I would like to purchase something as I know it would look neater and more tidy (providing the price is right).
The one thing someone has suggested is cold cathode tubes, use in computer modding - this is not quite what I'm looking for.
A good example of what I want can be found at:-
http://www.tridonicatco.com/kms/cms/...556&det_back=1
- but I can't find where to purchase these from (plus its not a website from the UK, and I would prefer to deal with British companies).
Can anyone suggest places to buy the above from (web addresses would be appreciated), and also, if anyone knows of the actual name of the 'gadget' I'm looking for!
Thank you in advance!!!
Old 23-07-2005, 2:03 AM   #2 (permalink)
Zog
Thanks: Gave 1, Got 5
Try these people
LightGraphix
But be aware, that the glass has to contain certain properties or it wont be very effective. (Think it has something to do with it containing iron?)
Zog is offline   Reply With Quote
Old 17-05-2006, 7:07 PM   #3 (permalink)
LED Shelf lights
You can try these guys - they do white LED shelf lighting:
http://www.think-lighting.co.uk
NigeUK is offline   Reply With Quote
Old 17-05-2006, 8:09 PM   #4 (permalink)
If you're anywhere near an IKEA, their Tretionnen product would probably work. Available in white, blue and green.
Frederific is offline   Reply With Quote
Old 17-05-2006, 10:38 PM   #5 (permalink)
shahedz's Avatar
Thanks: Gave 788, Got 425
another heads up for the Ikea lights, i have them and i think they could easily do what you want them to do
Linn Kolektor pre amp & LK140 amp,Genki,Sony MD MDS JE510,Sonos ZP80 + CR100,Ariston RD-40 turntable,TDL RTL3 ,Samsung32R87, Yamaha YSP-1000,Panasonic PT-AX100E projector,Toshiba HD-E1 ,Sky HD, PS3,Harmony 885
shahedz is offline   Reply With Quote
Old 05-06-2006, 11:59 PM   #6 (permalink)
plubraich's Avatar
Thanks: Gave 0, Got 2
Ikea
Another vote for ikea... I have some... they work really well... mount them inside black document clips to stop and clip them onto the back of the glass, to stop the stray light bouncing all over the walls etc...
plubraich is offline   Reply With Quote
Old 17-06-2006, 6:00 PM   #7 (permalink)
MDN
LED Shelf Lighting
try this link work very well, should have several options http:// www.litewave.co.uk the image on their home page of cinema was one of my projects
MDN is offline   Reply With Quote
led, lighting, shelf
