Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 09-07-2005, 3:44 PM   #1 (permalink)
Question issues with halogen lights in bathroom roof
Hi all,
Got an issue with my halogen lights in the bathroom ceiling..
Since last night 2 are not working yet 2 are... just been up the attic and noticed they are connected in series, so checked the cabling and all looks ok, also swapped the lights that are working with the others that are not and they all work, so lights ok (just not working when fitted)...
they do have transformers fitted to each light, don't think they can be at fault... not 2 at the same time blowing...
anyone any ideas, before i spend a fortune on a sparky
regards
Paul
chippy436 is offline   Reply With Quote
Old 09-07-2005, 8:13 PM   #2 (permalink)
Thanks: Gave 25, Got 108
Either meter the low voltage side of transformer on one of the non working fittings or just swap it for a working unit & you will soon find out if it's the transformers.
neilball is offline   Reply With Quote
bathroom, halogen, issues, lights, roof
