07-07-2005, 9:09 AM
#1 (permalink)
| | Member
Thanks: Gave 0, Got 0 | InfraRed Power Switch  Hi,
I own a Sony CE595 5 Disk SACD player which unfortunately does not come with an option to turn it on or off via the remote control. Does anybody know of where I can obtain an IR controlled adapter plug or know of anyway of wiring in an IR switch into the mains line to control the on/off function. Please note I do not want and RF solution such as the X10.
Basically what I need is something like a IR remote light switch that has an on/off function but without the dimming function
Reason: added more info
06-07-2006, 2:19 PM
#2 (permalink)
| | Member
Thanks: Gave 38, Got 20 |
Wildly long shot here, but did you ever find this?
06-07-2006, 7:36 PM
#3 (permalink)
| | Member
Thanks: Gave 12, Got 13 |
dont think these exist
06-07-2006, 11:24 PM
#4 (permalink)
| | Member
Starting to look that way, seems quite a few would like them, but nobody sells them.
I guess I can see the logic in RF ones over IR, but with universal IR remotes being so popular there's surely a market for IR versions.
07-07-2006, 7:55 AM
#5 (permalink)
| | Member
agreed, I think you can us x10 as an alternative though
29-07-2006, 12:14 PM
#6 (permalink)
| | New Member
Thanks: Gave 2, Got 0 |
What about this? http://website.lineone.net/~remotes/Page6.html
One of the types with multiple versions says that there is "Automatic self learning code" - I'd be interested in understanding whether that means we can set the IR code as in with my current light switches (so there for example, I just used a redundant button/code from something and then used that as the toggle code).
31-07-2006, 6:48 PM
#7 (permalink)
| | New Member
Thanks: Gave 2, Got 0 | for a cheaper option...
try Machine Mart, lots cheaper than that site.
31-07-2006, 7:37 PM
#8 (permalink)
| | Member
Thanks: Gave 1, Got 5 |
l bought the 4 pack of remote controlled sockets from lidl for £9.99 exactly the same 1's that are on their website ,some difference |
08-09-2007, 5:27 PM
#9 (permalink)
| | Member
Thanks: Gave 26, Got 4 | Re: InfraRed Power Switch
I am in exactly the same situation.
I need infrared, not RF.
Please advise!
19-09-2007, 12:24 PM
#10 (permalink)
| | Member
Thanks: Gave 0, Got 10 | Re: InfraRed Power Switch
I had this problem and use a IR to X10 adapter (IR543 I think) and a plug in appliance module. This is controlled using my NEVOSL.
I also have a plug in appliance module at my SkyHD box to enable me to remotely hard boot it when it crashes.
You now have the ability to IR remote control anything using plug in or wired X10 modules.
Hope this helps,
Simon
29-07-2008, 8:44 PM
#11 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: InfraRed Power Switch
hi all new here and dont know if this was answered (i know its a few years back but i found this site http://www.instructables.com/id/Univ...Switch-for-PC/
not sure if they post to uk though) hope it helps. http://www.simerec.com/PCS-2.html
the reason i posted is i want to do this myself and couldnt find any solution but the two sites i found above.
if anyone know where i can get this over in u.k or know a better one i can make. please reply.
thanks
10-08-2008, 9:58 AM
#12 (permalink)
| | Senior Member
Thanks: Gave 264, Got 200 | Re: InfraRed Power Switch
IR remote switches do exist. http://koolatrononline.stores.yahoo....te-switch.html http://www.amazon.com/Koolatron-IR-R.../dp/B0006II7CO
Unfortunately can't see the brand name from the photos.
I'm after a IR remote plug/mains socket so that I can turn a floor lamp on/off using my Harmony One remote.
__________________ Pioneer PDP-LX5090, Denon AVC-A1HD, Denon DVD-A1XVA, Denon DVD-2500BT, IsoTek G11 Mini Sub Mains Conditioner, REL Stentor III Subwoofer, FL+FR:KEF Reference Series 205's, Centre:KEF Reference Series 204c, SL+SR:KEF Reference Series 201's, SBL+SBR:KEF Reference Series 201's, Pace Sky+ HD
10-08-2008, 2:05 PM
#13 (permalink)
| | Member
Thanks: Gave 1, Got 36 | Re: InfraRed Power Switch |
29-08-2008, 10:13 PM
#15 (permalink)
| | Member
Thanks: Gave 0, Got 13 | Re: InfraRed Power Switch
I've been looking at this recently: http://www.windtrap.co.uk/Standby-Sa...-Safer-PSX.htm
Apparently it can learn your IR code, and switch off whatever you connect to it. It's designed to save power when going to standby, but it could be taught to do other stuff I think.
