Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 22-06-2005, 7:04 PM   #1 (permalink)
Wiring Downlighters
Probably a simple question if anyone can help please. I am going to put in some mains 50W downlighters on dimmers. I have noticed that there are either 400W or 250W switches. Does that mean on a 250W switch I can put 5 downlighters and 8 on a 400W, and does the wattage relate to each switch i.e. a double 250W dimmer can have 5 downlighters wired to each switch. Can anyone help, this seems like a great forum which I came across - I am in the process of buying a plasma/lcd so I'm sure going to check out the other forums
Thanks Julie
drivememad is offline   Reply With Quote
Old 23-06-2005, 1:18 PM   #2 (permalink)
Hi Julie
The wattage on dimmer switches does relate to the maximum load on the switch, so yes 5 x 50W lights on a 250W dimmer, and the rating is normally per switch. Look on the back of the switch it should have the rating printed on each switch. If the rating is printed on the back of the face plate then 250W may be the maximum for the whole thing.
Dazza7 is offline   Reply With Quote
Old 23-06-2005, 4:43 PM   #3 (permalink)
Thank you Dazza7 for your advice, I'll make sure I double check that out
Old 23-06-2005, 6:26 PM   #4 (permalink)
owain_thomas's Avatar
Thanks: Gave 56, Got 54
bear in mind that you get more "buzz" off an underloaded dimmer: a 250W dimmer will make more noise with one 50W lamp attached than it would with more.
flickr
HC - Rotel RSP-1068 Processor, Mac Mini running Plex, Arcam A90, Totem Arro Speakers
TV - Panasonic TH42PHD8 with Lumagen HDP
owain_thomas is offline   Reply With Quote
Old 30-06-2005, 10:13 PM   #5 (permalink)
craigb279
Posts: n/a
Julie
Dimmer switches need to be "de-rated" when being used with mains halogen downlighters due the high power demand which these lights draw. Most manufacturers recommend that the dimmer rating be reduced by around 33% for mains halogen use. In other words, a 400W dimmer switch would be suitable for dimming around 270W (or 5 x 50W) effectively. I would certainly advise that you purchase the 400W dimmer as a min. as a 250W dimmer would be unsuitable for 250W mains halogen load (closer to 170W total load) and would be likely to damage either the bulbs, the dimmer or both.
Hope this helps
Craig
Old 26-07-2005, 9:22 PM   #6 (permalink)
Thanks: Gave 4, Got 26
Im considering 6 or 9 spots for my living room (3.5m x 4.2). Is this too many, and also if not, are 500-600w dimmers available?
diggler46 is offline   Reply With Quote
Old 12-08-2005, 11:14 PM   #7 (permalink)
Futronix make a P50 single circuit dimmer that can be used with mains voltage lamps or magnetic (wire wound) transformers. This is rated at 600W.
They also do a P100 which is two circuits at 300W (mains voltage lamps or LV (electronic or magnetic transformers))
You can also buy basic remote/touch dimmers such as Varilight from B&Q that may suit your application and cost range better. Check the loading in watts and the transformer compatibility.
check Futronix out at www.futronix.com and B&Q at www.diy.com
compolitus is offline   Reply With Quote
Old 25-05-2006, 10:11 AM   #8 (permalink)
hannahgibson
Posts: n/a
Help!
I've got a similar problem.
I'm planning on putting 7 halogen lights in to my bedroom on a dimmer switch. I've bought the lights from Wickes but it doesn't say anywhere on the box that they are dimmable. I already have the dimmer switch which I believe is only a 250w and I've no idea what I need instead. I take it I'm going to need dimmable hologen lights and a 500w switch? any ideas/tips would be vey useful.
hannah
downlighters, wiring
