Originally Posted by dnesdlrow Can someone please help?!
I've bought a B&Q IR dimmer but there wasn't any instructions on how to get my TV remote to control it. Is it simply a case of trying all the buttons in the vague hope that one works?!
Any help would be great.
Thanks |
Just a word of warning... make sure you use a "spare" button on your TV remote otherwise every time you go to turn the lights on or off you'll also affect your TV. The Varilight is also a bit choosy and doesn't like some codes, so you might find your chosen button will only operate the light every second press. It doesn't mean there's anything wrong with the switch, just that it doesn't like that code (button), so try another one.
Good luck.
