Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 16-05-2005, 5:01 PM   #1 (permalink)
How to test 'live', 'earth' and neutral wiring?
just bought a gang light with IR remote control.
After opening my house electrical plug, i realise the cables are not colour coded. How do i test whether r they live, neutral or earth wire?
riconeo is offline   Reply With Quote
Old 17-05-2005, 9:43 AM   #2 (permalink)
Thanks: Gave 69, Got 316
House electrical plug ?
Nick_UK is offline   Reply With Quote
Old 07-06-2005, 4:58 PM   #3 (permalink)
Abu
Abu's Avatar
Thanks: Gave 310, Got 156
if it is a plain plug u r on about then the top long pin is earth. If you were to open up the plug as you looked into it the one on the left will be neutral and that on the right will be live. (In the usual plug, can't be held liable for electric shock )
Cheers.
Abu is offline   Reply With Quote
earth, live, neutral, test, wiring
