Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 21-04-2005, 1:43 PM   #1 (permalink)
Thanks: Gave 26, Got 9
UV light in the house - how do I?
i got a car mag today (Redline) and you get a free 9 inch UV light strip that is wired to a car cigarette lighter plug.
i was thinking of cutting off the plug and fixing the light to the wall to illuminate some UV painted artwork when the room is dark.
How do i do it? Am i right in thinking i need to power it with 12volts and not directly through the mains!
Was thinking of maybe wiring it to a 12v battery (do they exist?) and wiring in a switch to turn it on or off - then i can just hide the switch away in a box where the light strip will shine up or down from.
Or do i need to find some kind of plug to wire it to and get a mains to 12v converter?
Many thanks
shaolin101 is offline   Reply With Quote
Old 21-04-2005, 4:11 PM   #2 (permalink)
Thanks: Gave 0, Got 2
Find out what the current requirement is and buy a suitable plug-in 12v AC-DC converter from Maplin or the like.
You can run it through any switch, as long as it can handle the current.
Darren
Darren Blake is offline   Reply With Quote
Old 25-04-2005, 4:48 PM   #3 (permalink)
Or just hire a sunbed
Sorry could not resist
hinesle is offline   Reply With Quote
Old 22-05-2005, 6:32 PM   #4 (permalink)
Talking
you can just hook it up to a 9v battery it would work allough it may not be as bright
R2D2 is offline   Reply With Quote
Old 24-05-2005, 7:18 PM   #5 (permalink)
Or get eight 1.5v batteries and wire them in series.
Dave R is offline   Reply With Quote
Old 25-05-2005, 7:53 AM   #6 (permalink)
Thanks: Gave 69, Got 316
You can get 12V "gel cells" which are essentially miniature car batteries which have a jelly electrolyte which prevents spilling. They're used in burglar alarms and UPS systems - Maplin sell them. High capacity, but quite heavy and will need periodic recharging.
Nick_UK is offline   Reply With Quote
Old 12-06-2005, 6:53 PM   #7 (permalink)
Thanks: Gave 23, Got 1
[FONT=Lucida Sans Unicode]you could always buy an interior uv light!!![/FONT]
try here:http://www.uv-light.co.uk/
lewis
lewis4lcfc is offline   Reply With Quote
Old 12-06-2005, 9:50 PM   #8 (permalink)
chedmaster's Avatar
Thanks: Gave 38, Got 33
i have the solution! had the same prob with pc case flourescents. buy this: http://cgi.ebay.co.uk/ws/eBayISAPI.d...776110627&rd=1
It means you can dim it however much you like as well. just cut the end off and join the wires.
Batteries will run out very quickly, and if you do use 8 x 1.5v, make sure you wire them in parallel not series, or you'll just get a very dim light that lasts forever!
chedmaster is offline   Reply With Quote
house, light
