Originally Posted by andybed
From the spec sheet for your dimmer K1535 WHI which is a 'standard"sdimmer it states that its "only suitable for normal tungsten filament lamps with internal fuses", so if this is your dimmer its looks like it will not work with your light fitting and halogens.
Andy
Don't underestimate the importance of the internal lamp fusing - many cheap unbranded lamps may not include this and therefore allow damaging high current faults to pass through the dimmer triac which often kills the dimmer as you have found. This problem with lamps killing dimmers happens in much more expensive lighting control systems too so it you want to avoid costly dimmer reaplcements you need to ensure you are using the correct lamps.
