AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
LinkBack Thread Tools Display Modes
Old 09-12-2004, 8:51 PM   #1 (permalink)
How to make a glass edge glow
Hi. My AV cabinet has 3 x 5mm glass shelves and I would like to make the front edge of them glow when the lights are off for projector viewing. I've tried taping a thin CCFL tube to the back of one but it was too bright and it caused multiple lines of light to shine along a side wall. Interesting effect, but not what I'm after! I also tried a couple of bright LEDs on the back edge, but they only came through as two small points of light on the front.
The glass edges all around are just a flat polish, with small bevels.
Any suggestions? Thanks, Niall.
tehn is offline
Old 09-12-2004, 9:25 PM   #2 (permalink)
Interesting. No idea really. Sounds like a review of GCSE Physics could be called for here. You may need to achieve TIR (Total Internal Refraction) to keep the light within the glass i.e. when the light ray tries to leave the glass to air at an angle greater than the critical angle (42 degrees from air to glass) it should refract back in like a mirror. When i (the angle of incoming light in relation to the normal) is equal to the critical angle (the angle at which it leaves the glass i.e. 42 degrees) then the light should touch the surface. Other factors like colour can come into play too... I think.
I'd just use a lamp
digisocialist is offline
Old 09-12-2004, 10:14 PM   #3 (permalink)
john59's Avatar
Thanks: Gave 1, Got 16
I think you have to diffuse the light source somehow, I seem to remember seeing this in a gadget shop somewhere a while back (not for sale but being used has a display) sorry I can't help anymore
john59 is offline
Old 10-12-2004, 11:30 AM   #4 (permalink)
Thanks: Gave 4, Got 43
Try painting some of that glass 'frosting' paint on the edges you want to glow. It should diffuse the light enough, though an experiment on something other than the table first would be a good idea.
Mat
avanzato is offline
Old 10-12-2004, 11:37 AM   #5 (permalink)
Has anyone tried using the long thin cold cathode lights people use for the inside of PCs? Would this work?
edit: Forget that...just re-read the first post!
Mango Bob is offline
Old 10-12-2004, 1:41 PM   #6 (permalink)
Thanks: Gave 16, Got 3
I was in Alders the other day and noticed that they had this effect on several of their glass shelve displays. I asked one of the sales geezers there where I could get them from but he wouldnt tell me! This was in a lilac colour flourecent light. Very effective. I want one too!
SAMSUNG PS50P96FDX, SAMSUNG LE32R87BDX, SAMSUNG LE19R7IBX, Kef Q9C Centre, Kef Q7 Fronts, Kef Q2ds Rears x2, Kef PWS2500 : Denon AVR-3805 : Denon DVD-3910 : PS3 : Toshiba HD XE1 , SKY HD : Atacama Equinox AV stand : QED Silver Anniversary : Interconnects by IXOS and QED. PS3 ID V8Mose
Mose is offline
Old 12-12-2004, 12:07 PM   #7 (permalink)
stevesorted's Avatar
Nice idea.only thing is cold cathode tubes from pc's are 12v.........what about el wire you can use for around dashboards etc. some of these have a battery pack using 2 aa batteries...not very bright but may be enough for what you want!
Pioneer PDP 434HDE Yamaha DSP-A1 Pioneer DV868AVi.Panasonic DMR-ES10.
Rotel RCD02. Kef Model Ones. Kef 200C. REL Storm 5. Mission Rears. Mission sats. Sky+ PS2.X-Box360. Marantz RC5000i
stevesorted is offline
Old 22-12-2004, 8:12 PM   #8 (permalink)
Location: Was London.. now Melbourne, (temporarily back in London!)
Thanks: Gave 5, Got 8
It's a peice of p***, just buy a "Touchlight" from stands Unique, it's designed to do the job!
My Kit:
AMP: Sony TA-DA9000es DVD PLAYER: Sony DVP-999ES HTPC: DIGN Based twin DVB tuner MCE2005 PROJECTOR: Panasonic AE900 PLASMA: Samsung PH series 50" HD ACC: HD FTA box, iPronto with NetX, Xbox 360, Xbox, PS2, GC
Now in Australia... anyone want me to slap Max Christofferson?
doink is offline
Old 10-01-2005, 5:16 PM   #9 (permalink)
strider-nje
Posts: n/a
try looking at this thread
My IR Mood Lighting
Respect to Lydecker fro this one
Old 18-01-2005, 11:41 AM   #10 (permalink)
duke748's Avatar
Thanks: Gave 15, Got 21
Would these led striplights not do the trick ?
https://sslrelay.com/led-lightbulbs....iew.shopscript
http://www.my-led.com/0101_led_accen...ranha_leds.php
duke748 is offline
Old 20-01-2005, 2:18 AM   #11 (permalink)
Thanks everyone for your suggestions. Yes, the glass shelves in Lydecker's setup are just what I'm trying to achieve. He's used a CC neon tube, so I'll try mine again. It may be the front shape of my glass that is causing the problems, so I may also look at frosting the front edge of the glass as suggested.
Otherwise, I'll try some EL wire which isn't as bright.
I'll post a pic if I'm successful. Cheers, Niall.
tehn is offline
edge, glass, glow, make
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
