Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Logitech Harmony One Discussion Thread - Part Three logiciel Remote Controls 696 19-11-2009 7:14 PM
For Sale : Harmony 900 remote sealed in box includes RF module cmclean Electrical Goods Classified Adverts 25 01-11-2009 5:38 PM
Harmony 555 with Toshiba Regza junkiepilot Remote Controls 66 28-10-2009 12:23 AM
Harmony 895 IR to PJ nigel17 Remote Controls 3 27-10-2009 8:10 AM
Harmony One - Keeping things off when starting an activity fonz Remote Controls 7 26-10-2009 11:27 PM
Old 26-10-2009, 10:49 PM   #1 (permalink)
Thanks: Gave 5, Got 1
Rako and harmony one
hi, in my lounge i have 2 circuits with 5 spotlights each. I would like to control these using Rako and a harmony one remote.
Correct me if im wrong, but to achieve this i need:
  1. x2 RDL500C (one for each circuit)
  2. Ravir (IR to RF interface)
  3. harmony one remote
so Harmony One --> RAVIR --> RDL500C
Is this it or do i need a rako control panel like the RCP07?
so Harmony One --> RAVIR --> RCP07 --> RDL500L
thanks in advance for any help!
PDP-LX5090 - VSX-LX70 - PS3 60g- KHT3005SE
soulburn1980 is offline   Reply With Quote
Old 27-10-2009, 11:58 AM   #2 (permalink)
Assured Advertiser
Liam @ Prog AV's Avatar
Thanks: Gave 5, Got 684
Re: Rako and harmony one
The control panel is just a wireless panel to also access the RDL500 directly. You will need both, the control panel to do the lights when you go in and out of the room. The RAVIR to do the lights with the remote whilst you are in the room.
Top Gear in HD - my two favorite things ever finally combined!!
call me: 01892 860801 / e-mail me: liam@progressive-av.com
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Liam @ Prog AV is offline   Reply With Quote
soulburn1980 (27-10-2009)
Old 27-10-2009, 6:09 PM   #3 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Well, a mode scenestyle is a muych better option easier to fit and cheaper Welcome to SceneStyle.co.uk - The Stylish Way To Control Your Lighting
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 27-10-2009, 7:13 PM   #4 (permalink)
thanks for clarifying. I've never owned a harmony remote, is it easy to program for the above requirements?
I did some research on Rako and i found references to compatibility with Pronto and other brands, but not harmony which im more keen on...
Old 27-10-2009, 7:52 PM   #5 (permalink)
Thanks: Gave 25, Got 108
There will either be re-existing codes in the Logitech database or you can teach the Harmony new codes using the lighting manufacturers IR remote.
neilball is offline   Reply With Quote
Old 27-10-2009, 11:33 PM   #6 (permalink)
thanks
Old 28-10-2009, 12:54 AM   #7 (permalink)
Assured Advertiser
The IR control of Rako is is dependant on the install and programming of the rako units not a discrete set of commands.... The Rako software generates the HEX for control, HArmony cant accept HEX directly...
Old 28-10-2009, 9:32 AM   #8 (permalink)
Assured Advertiser
A trained Rako installer would have the master remote that you could learn the codes in from, and the Harmony database has some codes stored for it. Pronto support is much better though with more discretes for scene selection and multiroom if I remember (I don't really use Harmony remotes).
harmony, rako
