| Re: lights dim via 12v trigger?
You can also do what you want with x10 too.
One of these for sensing the 12v trigger: SM10 Universal Sender Module - X10 - Marmitek - Transmitters - Home automation - Comm4All
This will send an x10 command via existing mains cables to one of these: CM15Pro ActiveHomePro Interface - X10 - Marmitek - Controllers - Home automation - Comm4All
CM11 version is a cheaper version.
These interfaces can be used to trigger a macro on sensing the on command.
Macros can then do a lot.. such as dim, brighten. on , off of many lamps and sockets at the same time or with timed delays.
To act upon the x10 macro commands sent via mains you will need either plug in or in wall receivers. These will receive the commands from the macro and switch on, off, dim , brighten etc. Receivers - Home automation - Comm4All
With one of these you can also use a remote to control x10 lights and sockets. IRRF7243 RF Infrared Controller - X10 - Marmitek - Controllers - Home automation - Comm4All
The only thing with x10 is that it can be unreliable due to mains borne noise. If its a problem then additional x10 mains filters may be required.
__________________ TVSonyKDL52W4000 AmpsArcamFMJA32,PioneerLX81 CD/DVDPS3,Oppo83MR,Pioneer737MRSpksB&W CM4,CM2,CMC SubsREL S1+B1,SVSPB13U+AS-EQ1 TactileSoundEarthquakeXJ600R,Quake10B TunerRotelRT950BX SatPace2600Ci,Humax FoxsatHD+HDR,1.5mGilbertini,InvacomQDF-031,CM feedhorn RemoteHarmony1,RC3200,IR4PS3,x10 |
