Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 15-10-2009, 12:55 PM   #1 (permalink)
Thanks: Gave 0, Got 3
Is this possible?
what i want is `somthing` that will do the following IF possible
i want my celing lights to work as normal in my av room i.e a switch/dimmer to turn them on/off for normal use but when the projector/avr etc are switched on for 30 seconds -1 min later the lights to dim to low or off.
is it possible
* Panasonic PW7 Plasma * Denon 2805 * NTL Samsung SMT 2100C * Cheap DVD *Acoustic Energy Evo 3B 5.1 *
neal666 is offline   Reply With Quote
Old 26-10-2009, 1:56 AM   #2 (permalink)
007geezer's Avatar
Thanks: Gave 10, Got 7
Re: Is this possible?
is it possible
Yes! Its called the Wife
I just know ill get mauled for this.
007geezer is offline   Reply With Quote
Old 26-10-2009, 2:30 AM   #3 (permalink)
benmbe's Avatar
Thanks: Gave 176, Got 51
Thumbs up Re: Is this possible?
is it possible
Hi neal,
Yes it is possible ''without problems'' to program individual settings that can be tailored to each persons tastes.
I have been discussing this same subject with a reputable retailer, that is also fully trained in stallation of light fittings, room automation and so on.
They have explained that this same system can also be tailored to set lights for when you are on holiday.....they have recommended LUTRON SYSTEMS.
Their reason for choosing this manufacturer over some others is because of the top & reliable quality of the light fitting power transformers(they have a long reliable history of not failing.)
They have given me a price for about 8 light and transformers with control panel being £500, of which I am happy to pay.
Each room is classed as 1 x module and so I would want between 4 to 5 modules in my flat..
Of course if I want themselves to install this system then that would be an extra cost, but I have expressed that I would take annual leave, to help out with this installation.
Sorry for this long reply and hope this helps.
Honest Regards
P.S. These systems are also very economical(low) on power consumption
benmbe is offline   Reply With Quote
Old 27-10-2009, 11:43 AM   #4 (permalink)
Assured Advertiser
Liam @ Prog AV's Avatar
Thanks: Gave 5, Got 685
Easiest thing is an IR Dimmer switch (Lutron Rania for example) and a programmable remote. Insert into a the Macro for the remote for projector on a 30 second delay and the command to dim the light.
Some sort of control will be needed, a Lutron on it's own won't know when the AVR or PJ is being turned on or off. It would still need to be part of a remote control system or home automation system.
Top Gear in HD - my two favorite things ever finally combined!!
call me: 01892 860801 / e-mail me: liam@progressive-av.com
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Liam @ Prog AV is offline   Reply With Quote
