Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
LED Downlights? beduin Home Automation, Lighting, Security, Heating and Cooling 16 30-08-2009 9:47 PM
For Sale : Fixed Shower Downlights x 2 Edgeyboy Electrical Goods Classified Adverts 0 18-08-2009 6:36 AM
Buzzing from LV downlight transformers MarkP80 Home Automation, Lighting, Security, Heating and Cooling 6 18-07-2009 3:46 AM
Remote controlled dimmable LED downlighters - wise or foolish? Russtavo Home Automation, Lighting, Security, Heating and Cooling 18 16-07-2009 9:28 PM
downlight advice please leighprice23 Home Automation, Lighting, Security, Heating and Cooling 23 11-06-2009 1:46 PM
Old 11-10-2009, 8:41 PM   #1 (permalink)
Thanks: Gave 30, Got 3
Downlight Help Please?
Can somebody with some knowhow please give me some advice...
Have some lovely looking GU10 downlights throughout our kitchen and wanted to continue them through the new room im converting..however its an old extension with a low ceiling and the depth of the void is the depth of the rafters approx 100mm. The ceiling is currently down and old insualation removed.
Iv been told i shouldnt use the same downlights as the kitchen in there as they get too hot in the small depth of space and could ignite the new insulation, and id be better with led ones instead? Is this correct? Or maybe low voltage ones? Do they run cool enough? If the answer is led then do i need the all in ones, or do i just get led bulbs for the normal GU10 lights?
Any advice much appreciated, just want to get this ceiling back up safely
adamfernadam is offline   Reply With Quote
Old 13-10-2009, 4:37 PM   #2 (permalink)
Thanks: Gave 3, Got 23
Re: Downlight Help Please?
Screwfix sell firehoods that fit over the top of the downlights, and prevent the insulation from touching the hot light unit. They are very easy to fit.
Look for product codes 979320-99 and 84802-99.
I tried the LED route, but the bulbs are just not bright enough, and don't like being dimmed (even the dimmable ones).
Paul_McG is offline   Reply With Quote
downlight, query
