Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
New to internet radio - pls recommend some stations to preset RMCF DAB Digital Radio and FM Radio 15 16-10-2009 8:41 PM
2x6 matrix HD+IR+M.ch Audio distrib. over Cat6 calibos CAT5 Cabling 8 15-10-2009 12:02 AM
DAB radio with hard button presets? Typical Janner DAB Digital Radio and FM Radio 2 11-10-2009 7:09 PM
ir input sockets Ash007 Remote Controls 3 11-10-2009 6:31 PM
IR While Gaming mrlinderley Plasma Televisions 19 09-10-2009 3:44 PM
Old 11-10-2009, 5:28 PM   #1 (permalink)
Thanks: Gave 0, Got 7
IR dimmer with presets
Hi, I was wondering if it was possable to get a IR light dimmer than also has a few presets that will also work with my harmany one.
Dan
dreaddan is offline   Reply With Quote
Old 11-10-2009, 5:43 PM   #2 (permalink)
ITT
Re: IR dimmer with presets
hey dreaddan,
I currently used an ISY 99/pro IR with some insteon switches. Then I hooked up a Logitech 890 RF remote with it. On the ISY you can stick the IR transmitter from the RF modal and then after that its programming on your computer which was actually fairly easy. Our customers place has 15 lights, a fire place that I connected to an insteon relay, 1 motorized projector screen and 2 water fountains. We also installed a 6 scene wall switch (kind of like your preset question) and all of them I can now control with the logitceh as well. Really sweet system once it was all done. You can find all this stuff at smarthome.com, once we are completed this job Im going to shoot a video and post it up on our website for all to check out.
Jason
ITT is offline   Reply With Quote
Old 12-10-2009, 12:08 PM   #3 (permalink)
Thanks: Gave 155, Got 98
I think some x10 modules can remember last setting and also its posible with x10 IRRF7243 receiver and CM11/ CM15 PC interface and a Lamp module. You can create a macro to dim a light to an absolute level or a relative level. ie 20% darker of current setting or 20% of max.
TVSonyKDL52W4000 AmpsArcamFMJA32,PioneerLX81 CD/DVDPS3,Oppo83MR,Pioneer737MRSpksB&W CM4,CM2,CMC SubsREL S1+B1,SVSPB13U+AS-EQ1 TactileSoundEarthquakeXJ600R,Quake10B TunerRotelRT950BX SatPace2600Ci,Humax FoxsatHD+HDR,1.5mGilbertini,InvacomQDF-031,CM feedhorn RemoteHarmony1,RC3200,IR4PS3,x10
m4rky_m4rk is offline   Reply With Quote
Old 12-10-2009, 8:52 PM   #4 (permalink)
Cheers will have a look
Old 20-10-2009, 9:35 PM   #5 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Mode scenestyle has IR commands for presets Welcome to SceneStyle.co.uk - The Stylish Way To Control Your Lighting much easier than X10
hornydragon is offline   Reply With Quote
dimmer, presets
