Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Turn ts file from Humax to DVD? Gordon @ Convergent AV PVRs and VCRs 37 21-10-2009 8:15 AM
Acer aspire 7720 turns off san21 Laptops and Mini PCs 4 13-10-2009 12:27 AM
Switch to turn on light in the house wirelessly? bigfecker Home Automation, Lighting, Security, Heating and Cooling 7 09-10-2009 12:37 PM
Apple TV turns itself on.... pboreham Mac Hardware, OS and Software 6 01-10-2009 9:51 PM
Toshiba 32AV615DB turning itself on?! mclh LCD Televisions 3 30-09-2009 6:56 PM
Old 04-10-2009, 6:31 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Boiler won't turn off. Can anyone help?
We're having problems with our Baxi boiler. When both the heating and hot water turn off on the controller the boiler stays on, and keeps firing. However the issue is that it does this intermittently, it will go for a few days and be OK and then the problem will start again. This problem doesn’t occur when water only is on. We’ve changed the controller but this hasn’t helped. Can anyone help?
hs1972 is offline   Reply With Quote
Old 05-10-2009, 3:57 PM   #2 (permalink)
JLA
Thanks: Gave 4, Got 11
Re: Boiler won't turn off. Can anyone help?
have you checked your thermostat? maybe thats the cause and not the controller
JLA is offline   Reply With Quote
hs1972 (05-10-2009)
Old 05-10-2009, 6:47 PM   #3 (permalink)
That's a really good point, we hadn't considered it might be the thermostat.
Thanks for responding so quickly - it's really appreciated!
Best wishes,
Helen
Old 05-10-2009, 7:04 PM   #4 (permalink)
Thanks: Gave 104, Got 269
What do you mean by keeps firing exactly?
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (Silverstone case, IMON, Tosh HDDVD-ROM, E2200@2.5GHz, 4670 ultimate, 3GB, 80GB 2.5" drive, Sweetspot SDI card,Happauge HVR4000, Win 7 Enterprise), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
SeanT is offline   Reply With Quote
Old 05-10-2009, 7:48 PM   #5 (permalink)
Hi Shaun
By firing I mean that the boiler stays on after the programmers turned off - the pilot light is basically coming back on again. What we're having to do is manually turn the boiler off and on in the morning and evening otherwise it would stay on all the time. It doesn't happen however if we've only got the boiler switched to hot water (as we had in summer) it's only when we've got the boiler turned to heating and hot water. Hope this makes sense?
Best wishes
Helen
Old 05-10-2009, 8:04 PM   #6 (permalink)
OK, so it is control circuit related - by firing, I thought you meant sparking for a start (which would suggest a knackered thermocouple or gas valve)
Old 06-10-2009, 9:34 PM   #7 (permalink)
Need more details on the system for a more precise answer. Could be your motorised valve is sticking if it isn't the programmer, but depends on the type of valve and controls fitted.
watermead is offline   Reply With Quote
boiler, firing, heating, turn
