30-09-2009, 7:32 AM
#1 (permalink)
| | New Member
Thanks: Gave 2, Got 0 | HOMEEASY Remote Control
Hey Guys, just read some threads but I am still confused.
I just spent £100 on my Harmony One remote and I can't make it learn the codes from $homeeasy remote control.
Is there anything else I can do?
Thanks a lot.
30-09-2009, 8:07 AM
#2 (permalink)
| | Prominent Member
Join Date: Apr 2006 Location: You'd get your feet wet getting here
Thanks: Gave 198, Got 454 | Re: HOMEEASY Remote Control
i thought the homeeasy range was rf, the harmony one is ir
__________________ My Home Cinema Room My Gear: 108" Carada Screen, Panasonic AX100, Denon AVR3808, 7.1 B&W 6 Series speakers, Panny BD35(now Region free for Blu-ray!!), HTPC, XBOX 360, WII |
30-09-2009, 8:27 AM
#3 (permalink)
| | Member
Thanks: Gave 4, Got 11 | Re: HOMEEASY Remote Control
30-09-2009, 8:29 AM
#4 (permalink)
| | Prominent Member
Thanks: Gave 216, Got 402 | Re: HOMEEASY Remote Control Quote:
Originally Posted by mossym i thought the homeeasy range was rf, the harmony one is ir |
That is indeed correct.
Possibly of no interest, but in reply to a recent query by me, I received an email in which www.standbysaver.com said they are bringing out a range of IR controlled sockets etc in the near future.
__________________ Sony KDL46W5500, Sony STRDA2400ES, Sony RDRHXD870, Sony BDPS550, Sony TDMIP50, Samsung Sky+HD, XBox360+HD DVD, Sony VCR, 4 X Tannoy F4 Customs + Tannoy FC Centre + Tannoy TS10 Sub, Logitech Harmony ONE Yamaha YZFR1 MY STUFF KDL40P3020+BD35+HTPC, KDL46D3500+DAV-SC8(Bedroom) |
30-09-2009, 8:30 AM
#5 (permalink)
| | Prominent Member
i did get an ir controlled light switch from b&q, a varilight make one and it works perfectly with my harmony 1000, i have full on/off.dim functionality
30-09-2009, 12:00 PM
#6 (permalink)
| | Prominent Member
Originally Posted by mossym i did get an ir controlled light switch from b&q, a varilight make one and it works perfectly with my harmony 1000, i have full on/off.dim functionality | I got a couple of them from the B&Q rummage boxes t'other day, £1.50 each - They work great
However I also got a couple of Crabtree touch dimmers from the same box with no instructions and they definately don't work with low voltage lighting. I fitted one and it went pop the next day.
