| Extension build, thermal blocks or breeze blocks
I am getting a 2 story garage extension done v.soon.
I would like to insulate as much as possible so am thinking about using thermal blocks in the outer wall.
Can I use normal breeze blocks in the garage part or the ext. and then change to thermal for the back of the build which will hold a kitchen etc.
Will mixing two diff types of 'blocks' cause any problems with the wall? I am concerned it might weaken and cause cracks etc. Due to cost I dont really want to have to use thermal throughout
