3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
remote record gino555 Sky and Sky+ 5 04-07-2009 10:13 AM
Harmony controls are they worth it? Altn8 Remote Controls 24 28-06-2009 2:32 PM
SKY remote code for Kenmark? Niteflyer LCD Televisions 0 27-06-2009 12:45 PM
Comcast Remote Key Codes Mordeaniis Remote Controls 1 27-06-2009 11:54 AM
Old 27-06-2009, 1:57 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Lightbulb Remote controlled dimmable LED downlighters - wise or foolish?
I'm about to buy my first house and it needs a complete electrical rewire so I'm planning my lighting scheme. Things I want are:
- Dimmer controls (operating by touch and IR remote)
- Low costs
- Future proof
- Energy Saving
I like the idea of dimmable LED downlighters, though I understand this is not straightforward - problem is I'm very ignorant about Electrics so I have no idea if the kit I'm looking at are all "compatible". Like to get some brains on this
The VARILIGHT Remote Control and Touch Dimmers look like the ideal controls - the cost from TLC Direct seems reasonable - SEE HERE
The docs suggests for best results with Low Voltage Lighting, use VARILIGHT Low Voltage Transformers. I'm not sure their transformers would drive LED downlighters? However I discovered that Aurora make Dimmable Constant Current LED Drivers:
AU-LEDD48CC 1-16 x 3W Dimmable 700mA Constant Current LED Driver
AU-LEDD16CC 1-18W Dimmable 350mA Constant Current LED Driver
Alternatively there is also the Dialight Lumidrives VariLED dimmable 16-LED driver
I want mostly downlighters in the house and Aurora make LED ones which they specify as being dimmable:
AU-DLED301 350mA 1W LED Aluminium Fixed LED Downlight
It states that you should use their own AU-DSPLED dimmer unit but these are just rotary knobs. Do you think the VARILIGHT dimmers would work ok with this? Does anyone have better suggestions for the kit or am I am being foolish going down the LED route? Thanks to all!
Russtavo is offline   Reply With Quote
Old 27-06-2009, 7:23 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,328
Re: Remote controlled dimmable LED downlighters - wise or foolish?
To control LED properly is a lot more involved than controlling an incandescent bulb also if your rewiring then you can fit a proper lighting control system.
A word of warning every room i have ever seen with LED only lighting is terrible some clioents who had LED lighting throughout I(not installed or specced by us) have asked us to RIP it out and fit 12V halogen to at least 50% of the fittings for feature liginting LED is good for ambient light its poor.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 28-06-2009, 7:06 PM   #3 (permalink)
Thanks for the advice. It's only a small house but maybe I should just use LEDs for feature lighting. Hmmm I need to see them in the flesh really. Is there anyone out there happy with their LED downlighters?
Old 29-06-2009, 10:00 PM   #4 (permalink)
Thanks: Gave 2, Got 0
i brought some LED bulbs from B&Q and ended up taking them back as they were very dim. Ok for feature lighting or use where bright light is not needed.
Panasonic 42PX70:Sky HD:Onkyo605:Orb Audio 5.1:PS3 300gb
dbaplaya is offline   Reply With Quote
Old 30-06-2009, 7:35 AM   #5 (permalink)
Before I give up on LEDs altogether, has anyone experience of these downlighters by Collingwood:
Collingwood - LL030 Flood / Spot
They would be appear to be more suitable than the Aurora's as they are brighter with a greater "flood" angle (and dimmable of course). They might just fit the bill.
Old 30-06-2009, 11:09 AM   #6 (permalink)
Assured Advertiser
Dimmable by 1-10V and push to make only though
Old 30-06-2009, 12:41 PM   #7 (permalink)
I think I understand what you mean now, the LED driver needs an input voltage of 1-10v, problem being that apart from a few basic rotary ones, IR dimmers output upto 230v, is that right? In that case would the following bit of kit overcome this problem?:
Lutron GRX-TVI Control Interface Phase Control to 0-10V
Old 01-07-2009, 5:11 PM   #8 (permalink)
Found a great source of info for LED lighting including dimming:
http://www.hankselectric.net/pdf/Lut...LEDControl.pdf
Old 01-07-2009, 5:28 PM   #9 (permalink)
Assured Advertiser
Yes but you may need a Graphic eye to use it pretty much all proper lighting control systems have a 1-10V interface you just need the lighting control system Rako, Mode, Helvar etc
Old 02-07-2009, 12:53 PM   #10 (permalink)
Looks like your right HornyDragon, you need a Lutron Grafik Eye. Specifically the Grafik Integrale will do the business. But have you seen their prices?
Found another solution - would like some thoughts on - it's called Respondalight. It uses standard ethernet to power the fitting. There's a good thread on it here:
low energy led
Looks promising....
Old 02-07-2009, 9:27 PM   #11 (permalink)
Assured Advertiser
Its not ethernet it uses Cat5 as an interconnect (probably DMX based) and has RF remote by the looks of it so wont work with IR
Old 03-07-2009, 8:20 AM   #12 (permalink)
No, it's definitely IR, and I've been informed they do work with the Varilight dimmers - I will speak to them about that.
I did of course mean "ethernet cable" i.e. twisted pair.
Old 03-07-2009, 10:10 AM   #13 (permalink)
Assured Advertiser
You're right it is IR remote (rare and unusual in lighting systems asa line of sight sensor is required assume its built into the occupancy sensor)
Interested to here is they do work with varilight and how they are connected
Old 07-07-2009, 7:22 PM   #14 (permalink)
Thanks: Gave 4, Got 15
Just to point out that it is possible to get decent LED bulbs, but you won't find them at B&Q. I have a number of luxeon based lights in the bathroom and a single 50W halogen - down from 5 50W halogens. The luxeons are GU10 3W output - but are certainly not 50W halogen replacements - more light 15-20W halogen. I have a 5W luxeon type on oprder and will post when I get the chance to test it.
Interesting post - in our planned extension I want to do exactly the same thing...
robh2002 is offline   Reply With Quote
Old 07-07-2009, 9:16 PM   #15 (permalink)
Thanks: Gave 6, Got 6
I have just rewired my house and putting in mostly 9W LED downlights thoughout the whole house.Too me they seem bright enough and i think i am using only about 1000W.
I have not put in the lights just yet as house is just getting painted, hopefully it will be finished in the next few weeks so will try to get pictures up.
Also there are phase controlled dimmable drivers out there for using a normal trailing edge dimmer switch. But they are only 15W, but in august i know of a company releasing a 42W dimmable driver (traic controlled), so will be putting this in when ready.
aberdeenpaul is offline   Reply With Quote
controlled, dimmable, downlighters, foolish, led, remote, wise
