3.5 million visitors each month
Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Advice needed about CCTV cameras after switch Ziggy1968 Digital TV Switchover (UK) 10 26-10-2009 3:54 PM
Harmony Remote Multiregion DVD Hack for Panasonic, Pioneer & Sony Blu-ray's Pt.5 AV Junkie Blu-ray Players 1004 26-07-2009 4:41 PM
anyone using a tripod or anything else except ceiling mounted ? gill957 Projectors 5 21-06-2009 2:44 PM
Help with Ceiling Speakers Shermanator Speakers 9 21-06-2009 10:18 AM
remote control curtain closers??? grahamricho Home Cinema DIY 5 14-02-2002 7:26 PM
Old 21-06-2009, 9:19 AM   #1 (permalink)
Thanks: Gave 2, Got 0
Remote switch for ceiling lights?
Hi all
I am looking for some recommendation on what kind of products I could use to be able to individually control two light points (ceiling roses) that are currently connected on the same circuit.
To explain the setup a bit - we have in our living room a circuit with two lights on ceiling roses that are both two-way switched from two simple switches at the two ends of the room. That is, each of the switches turns _both_ lights on or off at the same time. I would like to be able to switch on or off each of the lights individually.
Any rewiring is out of the question as there is no access behind the ceiling. What I am looking for would be some kind of remote switches that I could embed into the light fittings, and the smaller the better... I have seen the HomeEasy range, but their bulbs and ceiling roses are too big - I would prefer something that could be encased into a spotlight track base.
Does anybody know of a product that could do that? Or any other ways to operate the two lights separately without major rewiring?
minute is offline   Reply With Quote
Old 23-06-2009, 7:25 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,328
Re: Remote switch for ceiling lights?
Rako is the ideal solution. They have dimmers that fit inside a back box, ot behind a rose that can split the 2 lights into seperate cicuits
Other option could be Varilight dimmer switch and slaves
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
ceiling, lights, remote, switch
