x10 via pronto - help?!
Hi, jsut spent all day rewiring my living room incroporating some x10 lighting modules.
Im using a marmatek 7243 to pick up IR signals from a pronto 7000. Everything works manually on the marmitek (lights on/off dim + -) and after hugh amounts of searching i found some codes for the pronto...
All on / Off doesnt work at all. Dim up and down does work. The problem i have is the On and Off does work, but i have to hold the pronto's button down for a few seconds.
This means no macros will work, as you physcially have to hold the button down, ive tried increasing duration, repeating the command and also heard about joining multiple repeat code onto the main code on the pronto but it doesnt work?
Has anyone come across this, or does anyone have X10 lights working via a pronto tsu7000 / 6000 / ru980 etc? If so be great for some tips / codes???
thanks!
IN76 projector - 32"Samsung LCD - Marantz 5300 - Mordaunt Short: 914, 905C, 902 - SVS SB12 - TactileTransducers - Xbox 360 - Vista Raid5 HTPC.
