Go Back   AVForums.com > Home Cinema Construction and Configuration > Home Automation, Lighting, Security, Heating and Cooling
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Pro Evolution Soccer 2009 Hints & Cheats + Option Files DJACID PS3 Games 47 22-05-2009 9:43 AM
DVD Recorder what are my options? stefanr DVD and Blu-ray Recorders, Recording and Media 5 22-05-2009 6:01 AM
Ambient Lighting Venture BradG Home Automation, Lighting, Security, Heating and Cooling 9 21-05-2009 8:32 PM
Old 21-05-2009, 10:13 PM   #1 (permalink)
Pulsar's Avatar
Thanks: Gave 42, Got 19
Lighting options with Grafik Eye
I'm currently converting my loft for use as a dedicated cinema room. I have a few plans as to what I want to do lighting wise, but I'm not certain on what to use in 2 areas.
1. Main down lighting.
2. Diffused up lighting
I have a Lutron Grafik eye (GRX 3104) to pick up from the post office tomorrow. I'll be honest and say that I didn't do all my research before buying this unit - luckily I think it is going to everything I need.
For the down lighting I need around 10 - 12 spot lights, probably not more than 35w each (guestimate) if we're talking traditional 240v GU10s which I have in my kitchen and bathroom. I am very concious of the heat this type of bulb gives off so I'd like to consider a low voltage version. My big question here is which type of LV spots work happily with a Grafik Eye?
For the up lighting ideally I'd like to go for some colour changing LED strip lights. I've seen these sold in 5m lengths on ebay etc and guess I'd need 3-4 of these. My questions here are:
1. What would be required to get these working with the grafik eye?
2. What controls the colour change of the lights?
3. What sort of cost am I looking at?
As always on AVF, I really appreciate any input I get.
Rob
Lounge - Denon 3805 :: 3x Quad 11L:: 2x Gallo A'Diva :: Sky+HD :: Panasonic PZ85 :: XBOX 360 :: PS3 :: Wii
Loft Cinema - Denon 2809 :: 3x M&K 2510P:: 2x M&K S150 :: SVS PB2+ :: HTPC :: Sky+HD :: Sony HW10 :: DIY Center Stage XD Screen :: Harmony One :: Lutron Lighting
Pulsar is offline   Reply With Quote
Old 22-05-2009, 8:03 AM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Re: Lighting options with Grafik Eye
FOR control of RGB LEDS you will probably need a DMX interface for the graphic eye (not cheap!) AS long as you use dimmable transformers most 12V halogens are fine.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 22-05-2009, 9:36 AM   #3 (permalink)
Pulsar's Avatar
Thanks for that. How about if I used single colour LEDs? Could these be direct controlled by the Lutron and dimmed?
Rob
Old 22-05-2009, 9:38 AM   #4 (permalink)
Assured Advertiser
Only if you found dimmable LED's look at Aurora
eye, grafik, lighting, options
