18-05-2009, 1:20 PM
#1 (permalink)
Thanks: Gave 3, Got 4
X10 Help Please?
Hi All
Just got the marmitek infrared controller & x10 appliance module for use with my harmony remote and im having issues
i got it all set up and working everything ok when pressing the button on the remote 'Click' goes the plug etc.
But! when i plug my appliance into the module around 5 seconds later it just 'Clicks' and the module turns on, on its own without getting any instruction to do so. ive changed the freq's and it does the same all the time.
Does anyone have any advice or ideas to why this is doing it? im really confused lol
thanks all
19-05-2009, 2:29 PM
#2 (permalink)
Thanks: Gave 151, Got 91
Re: X10 Help Please?
Have you tried it in another socket in another part of the house? I had one of mine doing soemthing similiar. I moved itr and it was OK. I used a different x10 AM and it has behaved perfectly.
TVSonyKDL52W4000 AmpsArcamFMJA32,PioneerLX81 CD/DVDPS3,Oppo83MR,Pioneer737MRSpksB&W CM4,CM2,CMC SubsREL S1+B1,SVSPB13U+AS-EQ1 TactileSoundEarthquakeXJ600R,Quake10B TunerRotelRT950BX SatPace2600Ci,Humax FoxsatHD+HDR,1.5mGilbertini,InvacomQDF-031,CM feedhorn RemoteHarmony1,RC3200,IR4PS3,x10
19-05-2009, 5:21 PM
#3 (permalink)
Thanks for your reply M4rky i have tried the module in another plug and another appliance and it works. but the minute i try to use it with my 2 computer case fans im trying to use it with, it plays up
Confused lol
20-05-2009, 11:43 AM
#5 (permalink)
Originally Posted by KW1816
I thought that feature was only on the lamp modules?
20-05-2009, 12:49 PM
#6 (permalink)
Thanks: Gave 1, Got 9
Nope - both Lamp and Appliance modules feature it - IIRC you switch the connected device On/Off/On to switch the X10 module.
20-05-2009, 7:53 PM
#7 (permalink)
I tested this onan AM12 and your are quite correct.
What may have caught me out is that it only seems to work for incandescent lights. I guess when I first tested first this function I must have used something it wasn't sensitive to.
20-05-2009, 8:53 PM
#8 (permalink)
thanks you guys for all of your replys
im still a bit confused and will sound like a right muppet but is that wiki saying to cut one of the wires within the module to get around this problem
sorry if im being a complete idiot i just dont want to burn down the house if i do something wrong lol
21-05-2009, 6:59 AM
#9 (permalink)
I checked with my supplier about the 'newer modules' He is telling me that they are not an official x10 product!!
21-05-2009, 10:32 AM
#10 (permalink)
Not sure what counts as an 'official' X10 product anymore - if there ever was such a thing. X10 has a long and checkered history (all the way back to a couple of blokes in Scotland circa 1974)  X10 Wireless Technology - Wikipedia, the free encyclopedia
If Letsautomate sell them that's good enough for me
Out of interest, who's your supplier ?
For the OP - The Wiki says cut the wire, personally I'd look at trying something else. What are you using to power the fans ? I'd try a different power supply first.
22-05-2009, 2:26 PM
#11 (permalink)
https://www.comm4all.com/index.php/language/en
