Rako question
Old 16-05-2009, 1:05 PM   #1
MarkP80's Avatar
6,231, Level: 18
Points: 6,231, Level: 18 Points: 6,231, Level: 18 Points: 6,231, Level: 18
Thanks: Gave 112, Got 99
Rako question
I'm in the final stages of planning a lighting installation for my bathroom. The lights will be controlled by a 7-button Rako wall switch. I have a number of scenes planned for the room, but there's a final thing I need to do.
I intend to fit a blue LED "nightlight" to give a little illumination at night - and hopefully encourage the teenagers to turn the lights off! I don't want to use a scene button for this, I'd like it to come on when the "off" button is selected on the wallplate.
So, that's the question - is it possible to programme the Rako units to turn a light on when "off" is pressed? (And I really don't want to start messing about with relays etc, I'd like to do it with a Rako module if I can)
Many thanks,
MarkP
Old 16-05-2009, 1:56 PM   #2
MarkP80's Avatar
6,231, Level: 18
Re: Rako question
Just a thought, but the LED I was going to use was the Micromark Twilight 66 kit - I have a transformer unit spare from when I put some in the garden. I've noticed that they now do a dusk-to-dawn sensor, so maybe I could just fit one of those....
MArkP
Old 16-05-2009, 9:00 PM   #3
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Rako question
HI mark there a couple of ways to do this (are you running a timeclock in the property?) or do you RASOFT?
Old 17-05-2009, 9:08 AM   #4
JohnS's Avatar
9,453, Level: 23
Points: 9,453, Level: 23 Points: 9,453, Level: 23 Points: 9,453, Level: 23
Thanks: Gave 6, Got 30
Re: Rako question
What about using a dusk till dawn type sensor that is only switching the led's. It doesn't need to be part of the Rako system at all.
Old 27-05-2009, 9:22 AM   #5
MarkP80's Avatar
6,231, Level: 18
Re: Rako question
- HD, no timeclock, but your question has just made me realise that if I set the LED to turn on when everything else was off, then it would be on all day. Doh! So I guess that isn't really what I want to do. I won't be using RASOFT, I'll be setting all the scenes just using the wallplate.
- Hi John, I think your suggestion may in fact be the simplest. I see the manufacturer of my LEDs offer such a switch, so that may be the easiest way to go.
Thanks for now, I'll let you know how I get on.
MarkP
Old 27-05-2009, 4:40 PM   #6
JohnS's Avatar
9,453, Level: 23
Re: Rako question
Any old dusk to dawn timer will do, I've got a couple of feature led's in a downstairs toilet and we use a cheappo dusk/dawn switch from Screwfix.
MarkP80 (28-05-2009)
