Help If you could with VTPro ?
Old 05-05-2009, 12:03 PM   #1
2,892, Level: 12
Points: 2,892, Level: 12 Points: 2,892, Level: 12 Points: 2,892, Level: 12
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 1, Got 14
I am only a trainie in the crestron field so dont laugh if you think this is easy i have done it before but i just cant remeber having one of them blank moments.
I want to switch touchpanels when i hit F12 to upload the project it says 'Target : (touchpanel)' i cant remember how to change this im trying to up to a TPS2000L via cresnet any help with in the next view hours would help
Old 05-05-2009, 7:14 PM   #2
4,602, Level: 16
Points: 4,602, Level: 16 Points: 4,602, Level: 16 Points: 4,602, Level: 16
Re: Help If you could with VTPro ?
You should be able to pick any address book entry you want after compiling? Are you running the latest version of the Crestron website?
Old 05-05-2009, 8:46 PM   #3
2,892, Level: 12
Activity: 0.7%
Yer i am. I try to look through the address book but it doesnt pick it up i tryed doing it through the processor and putting the cresnet ID but it didnt pick it up that way ever .
Old 07-05-2009, 7:06 AM   #4
4,602, Level: 16
So does it not show up or does it show up and not connect when you select the entry?
If it doesn't show up you need to add an entry.
If it does show up go in to toolbox and the network tree and make sure it shows up with the correct ID. If it doesn't show on the ID you were expecting you either need to change its ID or your toolbox entry.
If the above doesnt solve it then let us know which device you are trying to talk to.
Hope some of that helps!
Old 07-05-2009, 10:33 AM   #5
2,892, Level: 12
Activity: 0.7%
The cresnet ID's are all fine i checked over them about 25 times id say now redone the wiring incase there was a problem checked everywire but still nothing.
I am trying to connect to a TPS2000L using a CP2E i think its some thing to do with the entry's but they seem fine as well
Old 07-05-2009, 2:18 PM   #6
6,387, Level: 19
Points: 6,387, Level: 19 Points: 6,387, Level: 19 Points: 6,387, Level: 19
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 12, Got 25
hi james
make sure you have the default adress book open in toolbox
select the remote console to cnet ID entry field
on the right should be a dialogue box which says device is at
make sure this is selected on cresnet then select the cresnet id
also make sure that contact through at the bottom is selected to serial on com1
note you must have a RS232 straight through connected on com1 for this to work!
if it wont upload still unplug the cresnet connection from the tps-2000 place your thumb on the screen while applying the cresnet connection back in and the panel should boot into setup mode. Double check the cresnet id on the setup menu of the tps-2000 matches the entry in toolbox
also check the cresnet connection is wired red,white,blue.black ie 24 = red ect ect
Old 07-05-2009, 2:52 PM   #7
2,892, Level: 12
Activity: 0.7%
I cant select the remote console to CNET entry in address book it displays an error off :-
'The device could not be identified. Reason: The device failed to respond when requested for its identity.'
Its all wired up correctly and the TPS ID is correct as well.
Getting on my nerves now
Old 07-05-2009, 3:30 PM   #8
6,387, Level: 19
Activity: 1.5%
can you take a screen shot and email it to my work email address?
