Garden Control - Home Easy HS440
Old 03-04-2009, 9:09 AM   #1
8,594, Level: 22
Points: 8,594, Level: 22 Points: 8,594, Level: 22 Points: 8,594, Level: 22
Thanks: Gave 286, Got 552
Just a quick post to say how pleased I am with the HE440.
This kit allows you to control up to 4 separate outdoor electrical products independently using the HomeEasy remote control timer, with a maximum combined load of 3000W. Connect 4 garden appliances into each of the 4 outlets concealed in the outdoor box. Use the Timer Remote Control to turn Home Easy receivers on and off as you please or at your set time.
I have just built a garden water feature which utilises a pump and spotlights.
Granted, the HE440 is a bit of an overkill for just two outlets but I liked the one box and timer/manual Remote operation.
Works a treat, just need to think of what to use the two spare outlets for .
Only minor criticism is the lack of cable anchor points inside the box.
Old 28-04-2009, 10:11 AM   #2
1,603, Level: 9
Points: 1,603, Level: 9 Points: 1,603, Level: 9 Points: 1,603, Level: 9
Thanks: Gave 0, Got 2
Re: Garden Control - Home Easy HS440
Looks like the kind of thing I am looking for to control my decking lights and floodlights!
How much are they, and what was the best supplier?
Thanks,
Rich
