Patch panel hardware?
Old 08-03-2009, 2:08 PM   #1
5,636, Level: 17
Points: 5,636, Level: 17 Points: 5,636, Level: 17 Points: 5,636, Level: 17
Thanks: Gave 3, Got 4
I'm planning to install home network wiring in my flat, but I'm finding it difficult to find the hardware I need.
I want to put the patch panel and modem/router/switch/wireless access point on the wall in my airing cupboard, below the mains consumer unit (there's nowhere else for it to go). So I'm looking for a surface wall-mount box around 10cm deep with space for patch panels and electronics. I'd like to have a switch with at least 16 ports and preferably I'd like a wall box for an RF distribution amp too.
The wall boxes I've seen only seem to have room for a small combined modem/router/switch, but I think I'd need to get a separate switch to get 16 ports.
Can anyone recomend a suitable wall box, and suitable switch/ADSL modem (& would I also need a separate router)?
Old 08-03-2009, 3:44 PM   #2
dj-dulux's Avatar
4,381, Level: 15
Points: 4,381, Level: 15 Points: 4,381, Level: 15 Points: 4,381, Level: 15
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 10, Got 132
Re: Patch panel hardware?
This may be what you are looking for, here. Have a look around the site as he has a few other options too.
Dupe...
Last edited by dj-dulux; 08-03-2009 at 3:49 PM. Reason: Changed link as more suitable product...
